No this will deliver a fantastic picture via SDI. It does have chroma issues but then the DVDO will filter those out for you. Also this will get rid of the MBE bug of the faroudja chipset. as with SDI the signal will no longer pass through the faroudja chip
SDI takes the pic straight from the mpeg decoder, so unless theres a machine with a far better mpeg decoder you want see much difference from a different machine, as long as the SDI mod is done right. A dodgy mod can look bad to say the least.
Audio wise the A11 was rather good if i remember correctly so no real need to boost that. Having SDI is much the same as having HDMI (without the audio) although i think only the new pioneer 989 garentees that the signal passes from the MPEG decoder direct to the scaler with zero processing. Even the 868i had some processing done so was not a pure signal like SDI.
Maybe take a look at the pioneer 989avi, only other machine that would be a big upgrade would be the denon A1xv but then its cost is huge.
Dustin.
