Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 7:30am and include delivery.
Old 20-08-2005, 11:03 PM   #1 (permalink)
Thanks: Gave 4, Got 5
DVD player fault - any ideas?
My Toshiba SD 220 DVD player has suddenly started to refuse to recognise any DVD.
At first I thought it was the rented DVD I was trying to play that was the problem but that played fine in two different PC's.
I then tried known good discs that I own and the same thing happened. It claims there is a disc error each time I try and play a disc.
Insert a disc and it says "loading" but then there are several clicks from the mechanism, a whirring sound as if it is trying to fiind the start of the disc. This is repeated several times before an error message is displayed on the screen saying check the disc.
Has anyone had this sort of problem before?
Dave
Dune is offline   Reply With Quote
Old 21-08-2005, 8:50 AM   #2 (permalink)
Thanks: Gave 0, Got 2
Well I had similar problem but with my PC DVD, there are two possibilities:
1. Your laser needs calibration, depends on value of the player it might be not worth it.
2. Laser needs to be cleaned, you can try all those cleaning disks
It happened once with my Playstation 2 too, drive was not picking up any dvds but was playing cd, check in your player if it is like that your laser is probably gone
Hope that helps
Lucas
lukassk is offline   Reply With Quote
Old 21-08-2005, 2:01 PM   #3 (permalink)
expat's Avatar
Thanks: Gave 27, Got 10
The same kind of thing happened with my first DVD player (from Philips). This was about two months after the guarantee expired. Cleaning didn't help in my case. Repairs would have been more than the cost of a new player...
Panasonic TX-P50GW10, Sony BDP-S350, Denon AVR-2802
HTPC: Silverstone SST-GD01B-MXR, Asus P5K-E/WIFI-AP, Intel Core 2 Duo E6750, 8600GTS, Toshiba SD-H802A HD-DVD, 2xSamsung HD501LJ, Vista Home Premium 32bit
Speakers: Focal Expression Fronts, JMLab LCR700 Center, JMLab SR700 Rears
expat is offline   Reply With Quote
Old 21-08-2005, 9:41 PM   #4 (permalink)
Right, thanks for the replies. I'll try a cleaner disc but I can see a trip to the local Richer Sounds on the horizon
It isn't that old and I can't say it has seen heavy use.
Dave
dvd, fault, ideas, player
