07-05-2005, 7:45 PM
#1 (permalink)
marantz 7600
Have been looking at getting one of these new units ,they look by the specs to be pretty good,does anyone actually own one of these and what are they like?
09-05-2005, 8:15 AM
#2 (permalink)
Thanks: Gave 5, Got 20
I take it you mean the DV7600? if so they are not available yet. Should be in a month or so.
09-05-2005, 9:02 AM
#3 (permalink)
Thanks: Gave 1, Got 1
looking at the spec and it says progressive scan and in brackets ntsc. Does this mean none on pal? Are these machines really built for the us market and pal an afterthought? Shame if so as it looks a nice machine
09-05-2005, 9:37 AM
#4 (permalink)
No it will do both pal and NTSC progressive, and will upscale both to 720p or 1080i on the HDMI output.
09-05-2005, 10:04 AM
#5 (permalink)
Thanks: Gave 30, Got 20
got a matantz dv9500, 7600 bigger brother. Brilliant machine.great video and audio. PAL and NTSC progressive through components and HDMI. Not to mention Upscaling to 720p and 1080i.
The 7600 and 9500 are identical video wise,but the 9500 audio section has been beefed up!!
09-05-2005, 10:06 AM
#6 (permalink)
Thanks: Gave 0, Got 2
I thought 9500 video dacs were 14bit and 7600 12bit...
The above ramblings are those of mutley and are in no way endorsed by the AVForums.The views expressed in these posts do not necessarily reflect the editorial conclusions of AVForums.
09-05-2005, 10:50 AM
#7 (permalink)
would be interesting to know if they are the same as I don't ned cd replay on my dvd player
09-05-2005, 10:52 AM
#8 (permalink)
That is correct.
09-05-2005, 6:51 PM
#9 (permalink)
I not worried about the music side but i had a chance to see the dv9500 today and very nice it was two running on a 435xde.The picture looked really good,best i seen upscaling to 720p.It looks like the video side is the same as the 7600 so its convinced me into getting one as soon as they released.
09-05-2005, 7:59 PM
#10 (permalink)
They arent exactly the same, as mentioned above the 9500 is 14 bit and the 7600 will be 12 bit
10-05-2005, 11:50 AM
#11 (permalink)
yes,that's right 9500 has 14 bit dacs while 7600 has 12 bits !!
10-05-2005, 12:08 PM
#12 (permalink)
Thanks: Gave 127, Got 83
The DV9500 seriously rocks.
I was going for a DV7600 myself but just could'nt wait till June.
The DACs are different but I'm not so sure this will make too much of a difference if you use the HDMI output as it doesn't pass through the DACs.
There are a few differences to the audio side of things between the two players but I think its a safe bet they will both be excellent players!
Samsung LE40F71BX,Arcam AVR350,Arcam DV137(MR),Toshiba HD XE-1(MR),LG BD390(MR),Xbox 360 Elite,Nintendo DS Lite,B&W 603S3,B&W LCR60,B&W 601S3,BK Electronics Gemini II subwoofer,Topfield TF5810 PVRt,Logitech Harmony 525,Belkin PureAV PF50 mains conditioner,UHDC HDMI Switcher+LG Arena&Sanyo Xacti HD2
10-05-2005, 1:56 PM
#13 (permalink)
Hmm I would be using component on my plasma so then it would go through the dac's?
10-05-2005, 2:26 PM
#14 (permalink)
Yes, but you can expect great picture quality... just the 9500 is better...
10-05-2005, 4:24 PM
#15 (permalink)
You won't be able to take advantage of the players upscaling ability but the 576p output is still excellent.
