Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
LG DRT389H
Sony DVP-FX730
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Panasonic DMR-XS350 250GB
Samsung DVD-H1080
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 6:30pm and include delivery.
Old 09-02-2005, 1:58 PM   #1 (permalink)
Thanks: Gave 9, Got 4
Quick Question regarding the Samsung 745
Just ordered it to hook up with my Sony HS20 via DVI. When I input the region hack it turns off the HDCP, correct? If my sony is HDCP (not sure) does this mean the samsung will not work with it through DVI once its been hacked and the HDCP turned off
Contrary to popular belief not all us irish are alcoholics....Hic....!...hic
Thanks for reading
Vic
vicbarry is offline   Reply With Quote
Old 09-02-2005, 2:05 PM   #2 (permalink)
McE
Thanks: Gave 1, Got 10
it will work don't worry...
McE is offline   Reply With Quote
Old 09-02-2005, 2:50 PM   #3 (permalink)
Righto, Ill take your word for it. Cheers!
Thanks for reading
Vic
Old 09-02-2005, 3:19 PM   #4 (permalink)
Any second opinions, lol. So just to reconfirm if i turn off the HDCP through the hack it will play and scale through DVI to a HDCP source with no probs!
Thanks for reading
Vic
Old 09-02-2005, 3:55 PM   #5 (permalink)
McE
my sharp GD1E has DVI HDCP as far as I know and I did the hack with my HD745... everything works fine. It scales via component and DVI. Only thing is you got more blacks via component than DVI but I have to adjust the brightness and backlight on my sharp so high to see the aditional 3 blacks (via DVI there are only 7 out of 10 blacks in the THX optimizer from Starwars) that there is nothing black anymore... nobody will ever adjust his Sharp to such settings...
EDIT: Only for you mate I hooked up my Sony HS10 (hope it has HDCP)... It's working!
Old 09-02-2005, 8:52 PM   #6 (permalink)
Thanks: Gave 4, Got 2
Had a Cambridge DVD79 without HDCP worked fine with my sharp LC32GA4E.
Don't worry will be fine.
MickyGee is offline   Reply With Quote
745, question, quick, samsung
