Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 21st at 9:30pm and include delivery.
Old 23-01-2005, 4:18 PM   #1 (permalink)
Thanks: Gave 10, Got 7
Pioneer AX5Ai & 868 DVD iLink
Have a problem getting these 2 items to talk via iLink. If I go through the set-up menu and turn the iLink on and off then it works fine. Once set, if I turn the DVD off then on it displays Checking Link for a while but the blue indicator does not come on and I get no sound.
Anything I am missing to get these products to handshake consistantly?
SkyHD --hdmi--> Pioneer 436XDE (ISF Cal)<--hdmi-- Pioneer DV-868AVi --iLink--> Pioneer VSX-AX5Ai ---> 4 x Kef iQ7 | 2 x Kef iQ6c | Rel Q200E
The Digital Nirvana?
RobbieTT is offline   Reply With Quote
Old 23-01-2005, 7:10 PM   #2 (permalink)
Steve Zodiac's Avatar
Thanks: Gave 58, Got 136
I had the same problem with the same gear.
It was resolved when both the DVD player and the receiver menus were set accordingly for i Link. If only one is set, then it's a bit hit and miss when the i Link works.
DVD player: Initial settings/i Link etc, pages 77 & 78 of the DVD manual.
Receiver: System Setup/Input Assign/i Link, page 91 of the receiver manual.
Steve.
Steve Zodiac is offline   Reply With Quote
Old 23-01-2005, 7:37 PM   #3 (permalink)
Steve.
Steve,
Thanks very much, that fixed it! (so much for the auto-select!)
Now, if you could fix the problem that I have in RGB....
Regards,
Rob
Old 24-01-2005, 9:12 AM   #4 (permalink)
Rob,
I've had a look through the thread about the Pioneer 868 RGB problem and also just had a look at Star Wars II.
I use HDMI out to DVI and there isn't any problem whatsoever, but on component out, the ghosting effect is there very slightly. This can't be seen at all if I'm over five feet away from the screen. I'll perhaps connect an RGB cable later to see if it is any worse and maybe post the results on the 868 RGB thread. If this didn't happen on your Sony DVD player then I suspect that it could be a design fault on these players. I have previously read on this forum that Pioneer made the analogue outputs inferior simply to make HDMI look better.
Incidentally, I had the Sony 735 DVD player and in terms of overall PQ I wouldn't say that the Pioneer 868 is that much better...........even when using HDMI.
Steve.
Old 24-01-2005, 7:13 PM   #5 (permalink)
Steve,
Thanks again.
Rob
868, ax5ai, dvd, ilink, pioneer
