Well, the problem might not be more severe than the so-called macroblocking issues of the Panasonic S97... Of course it is a problem to be fixed, but as I understand from the swedish forum, it is more important to match the dvd-player to the display device. So if your display device's dvi-input is locked to PC levels (0-255) (like my Benq PE7800 supposedly is) it should be matching the Samsung 745 better than for instance the Denon 1910 which is locked to video levels (16-235).
I don't know how good your swedish is, but maybe you can get an idea of what I'm talking about looking at the illustrations here:
http://www.prisjakt.nu/forum/index.p...dpost&p=640065
dvd-spelare = dvd player
bildvisare = display device
normal = video levels (16-235)
expanderad = enhanced = PC levels (0-255)
