Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 9:30am and include delivery.
Old 02-08-2004, 8:37 AM   #1 (permalink)
Stevie Boy
Posts: n/a
Connecting DVD player to Home Theatre?
Hi all.
Bought a home theatre all-in-one (JVC THA5R I think), which has turned out to be a bad move Discs have always been skipping - now won't play anything (Keeps 'Loading' but never finds). This is now 18months old so I can't return. My question, as a newbie, is can I by a new DVD player but utilise the amplifier and speakers of the JVC? After good reviews I'm considering a Toshiba SD240E as my additional DVD player. I Know I'll need the audio in/out plugs but I've tested this and it didn't work - the only spare output I can see on the JVC is something called a Coaxial????
I need to know if above could work - or what features I should be looking for. Any suggestions would be extremely appreciated.
My 3 year old is desperate for his favourite Brum DVD (once I've scraped the jam off - which admittedly doesn't help!!!)
Cheers S
Old 02-08-2004, 8:50 AM   #2 (permalink)
DaveP
Posts: n/a
Welcome to the Forums.
You will need an Input on the JVC that will take the DD5.1 stream from the player. This will be either optical or co-axial.
The co-ax output you have found is no good for connecting to a player, it's probably for connection to an external amp.
Dave
Old 02-08-2004, 12:23 PM   #3 (permalink)
Greg's Avatar
Thanks: Gave 99, Got 752
Another welcome to the forums.
You posted this in the DVD talk forum which is to quote the description on the main menu 'Discussing DVDs. Talking about DVD suppliers and prices, discs good and bad, release date, specs and compatibility issues.'
I have moved this to the DVD players forum where you may get more response.
Hope your find your answer.
Greg
My opinions expressed here are not necessarily those of the AV Forums or the associated websites.
Science created him. Now Chuck Norris must destroy him!
Greg is offline   Reply With Quote
connecting, dvd, home, player, theatre
