Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 1:30am and include delivery.
Old 13-06-2004, 10:23 AM   #1 (permalink)
Thanks: Gave 12, Got 3
Problem with Pioneer DV-565A On Component
Hi Guys, need some advice.
Have pioneer DVD DV-565A. Works fantastic once set to progressive scan. However once you turn the machine off, then turn it on again, it still has light on front to say it is outputting prog scan, but get no signal out. No s-video output either so it's not resetting to other format. To get round it have to reset box, and go into options whilst viewing through s-video, then set it to prog scan again which will then work fine ??? very odd.
Any ideas - am I doing something stoopid??
Thanks, The Baldster.
Baldster is offline   Reply With Quote
Old 13-06-2004, 3:28 PM   #2 (permalink)
Ged
Ged's Avatar
Thanks: Gave 20, Got 14
Have you set the scart output to RGB? I think it needs to set to video or S-video otherwise you may loose component output.
Ged is offline   Reply With Quote
Old 13-06-2004, 3:35 PM   #3 (permalink)
Ged you star. All sorted thanks.
Old 13-06-2004, 3:37 PM   #4 (permalink)
Ged
Ged's Avatar
It's a pleasure.
component, dv565a, pioneer, problem
