Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Sony RDR-HXD995
Panasonic DMR-XS350 250GB
 More...Prices updated November 22nd at 5:30pm and include delivery.
Old 09-02-2004, 12:21 PM   #1 (permalink)
Thanks: Gave 2, Got 18
Pioneer DV-717 vs 737
I have a Pioneer DV-717 (region 2) and I noticed one of my local shops has a 737 second hand for £200 (not sure if it's mutliregion) - is that a good price and would it be worth me trading my 717 in against it, bearing in mind I wont use progressive scan?
kwebbotaurus is offline   Reply With Quote
Old 09-02-2004, 1:43 PM   #2 (permalink)
Erm I'd prolly save the £200 and keep saving for a while. I don't think the 737 is a worthwhile step up from the 717 IMHO.
Silver Panny PW6, DVDO IScan HD, Quintro+, Denon 2200, Panny HS2, Yamaha Musiccast, Roksan Caspian DSP + Caspian 5ch amp, NTL Cable Box, Xbox (Chipped+XBMC), Denon TU260L Mk2, Sounds Fantastic Bar, Ruark Prologue One R, Epilogue One R, Mission 77DS, Rel Storm 3. Optimum 6000 Rack
DucatiEVO is offline   Reply With Quote
Old 09-02-2004, 8:35 PM   #3 (permalink)
mutley's Avatar
Thanks: Gave 0, Got 2
717 doesn't have component out. does the 737? it might be worth it if you sell the 717 so that the difference is less than 200.
The above ramblings are those of mutley and are in no way endorsed by the AVForums.The views expressed in these posts do not necessarily reflect the editorial conclusions of AVForums.
mutley is offline   Reply With Quote
Old 09-02-2004, 11:54 PM   #4 (permalink)
Desperado
Posts: n/a
I have a 737 and also had a 717 before that
well i think it would be well worth it as the 737 has better Picture settings IMH the 737 will put all budget players to shame
and has Progressive Scan so if you be upgrading to a plasma later on the 737 would come handy
Regards
Old 10-02-2004, 11:59 AM   #5 (permalink)
Thanks: Gave 30, Got 20
737 while a very good player has been greatly superseeded by new players from pioneer. Hang on to your money and buy a newer generation dvd players like the pioneer 757,668 or even 868,you will be getting much more in addition eg dvd audio,sacd,iLink etc.
Not to mention other brand from the like of denon etc.
kumamoto is offline   Reply With Quote
Old 10-02-2004, 8:25 PM   #6 (permalink)
gandley's Avatar
Thanks: Gave 168, Got 287
having owned both id would not recommend that you buy it, side it isnt worth much over a £100.
its prog scan mode was quite poor due to poorly implemented deinterlacing..
id save and skip at least two generations more over 737. to make it worthwhile
Dustin.
gandley is offline   Reply With Quote
737, dv717, pioneer
