| Tosh SD330 Component Settings ?
Hi All
Ive had a search but cant find the answer......
Ive Just got a set of Thor Component Cables for connecting a Tosh 330SD to a Tosh 32Zd26 TV.
The setting for the DVD player are however a little confusing ! I have the choice of:
1)Video
2)SVideo
3)RGB
I was previously using RGB via scart but i have to choose "Video" to view a picture now - Is this the correct setting to use ?
The picture seems a little more detailed with the new cable and colours perhaps stronger too.
Thanks for you help
Kind Regards
Gareth
