Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 12:30pm and include delivery.
Old 12-01-2004, 12:02 PM   #1 (permalink)
vestrus
Posts: n/a
Cambridge Audio DVD57/Pioneer 565/Marantz4300
I just got a Cambridge Audio DVD57 to couple with a Marantz 5400
(the guy at Richer sounds convinced me that it was a good all-rounder for video and audio)
However, I'm not too convinced and I was wondering if I would be better off exchanging it for either a Pioneer DV565 or a Marantz 4300.
What do people reckon?
Also would I be best off using a digital connection to the amp and letting it do all the audio decoding?
Old 12-01-2004, 4:02 PM   #2 (permalink)
Thanks: Gave 20, Got 237
I don't know about the pioneer or marantz, but I got a DVD55 (which is the same as the DVD57 but without the DVD-Audio support).
IMO, the DVD55 is rubbish, and its built in de-coder is no less rubbish than the rest of the player. The P-scan output is completely unusable, the sound is poor (both digital and decoded) compared to my 3 year old Samsung player, the remote control is crap. I could go on.
Richer's did the same to me. Anyone that asks a salesperson for advice seems to end up being sold a Cambridge Audio dvd/amp/cd/tuner/car/house/wife or whatever the hell else they think you might buy.
I'm not an expert, but I think both the players you mention are NTSC prog-scan only (no PAL p-scan). They seem to be well regarded, but I *think* the Pioneer will only output an NTSC signal from its component connection - PAL DVDs are Scart / S-video only. I guess a lot depends on your TV. If you're using a normal (non-HD / Progressive Scan) telly then any of the players you mention will look OK, even the DVD57.
I miss my home cinema
Mr_Belowski is online now   Reply With Quote
Old 12-01-2004, 5:15 PM   #3 (permalink)
rupbert's Avatar
Thanks: Gave 25, Got 19
Cambridge Audio, now owned by Richer Sounds has produced a large bias on behalf of the RS staff...
A member of staff stated the Cambridge Audio Azure 640c was "significantly better" than a NAD 521i...
Shame he was not aware that I had a demo of both machines a few week before. They sound very, very similar...
rupbert is offline   Reply With Quote
Old 12-01-2004, 5:54 PM   #4 (permalink)
vestrus
Posts: n/a
Sorry,
I should have mentioned that the TV is only a 24" Widescreen Philips, but I plan to change this to a TV with Component Video input quite soon - I'd rather not have to buy a new DVD player at the same time.
I think I read somewhere that the Marantz 4300 does PAL p-scan (though it's some kind of conversion to PAL60).
I don't really care about DVD-A or SACD at the moment, though the Pioneer does both, just in case (though I can alway get an SACD player if I really wanted to)
The reason I ask is that the Cambridge Audio DVD57 didn't have that wow factor which kind of disappoints me a bit
Old 15-01-2004, 3:38 PM   #5 (permalink)
Thanks: Gave 0, Got 8
Marantz 4300
I just got a 4300 (2 weeks ago) and it is an outstanding DVD player. It has every connection you'll ever need (well maybe not DVI but...)
The remote is very good and has a good feel, the setup menu's are a doddle. It seems to play every disc I have thrown at it and the actual machine itself (I have it in black) is very solid and feels
like a Marantx should.
Only quibble is that the DVD players display is abit small to see if your sitting more than 10ft away (but you can change the brightness of it)
pepsi is offline   Reply With Quote
Old 16-01-2004, 6:20 PM   #6 (permalink)
Conspicuous Member
Gary Lightfoot's Avatar
Thanks: Gave 12, Got 377
I can concur with Mr_Belowski that the CA players aren't very good. I had tried a few players from Richers which I ended up taking back, and they pushed the 57, so I thought I'd try it.
The interlaced picture was very soft, and both PAL and NTSC had issues which meant they were unwatchable. That one went back too.
I've seen the Panasonic S75, and that gave a very detailed image indeed - on a par with the Pioneer 656 IMHO, and definately worth £100 MR which is the current price IIRC. The Toshiba SD52e was also very good, and I would have kept that but PAL images suffered from a slight green shift. Only noticable on a large screen though (probabaly 50ins or bigger).
Gary.
Gary Lightfoot is offline   Reply With Quote
Old 19-01-2004, 12:40 AM   #7 (permalink)
bobbypunk
Posts: n/a
Pioneer if you need universal playback
MArantz fo Picture quality and build quality
Cambridge audio @~#;
I may be wrong but:
RS don't own CA they are the sole UK distributor
RS probably (Due to this) get very good margins on CA stuff and so are probably telling there sales people to push them over the rest.
If people are looking for CA equipment they won't be shopping elsewhere as it's the only place you can get them.
But I refuse to take part in calling them crap, I'm happy to say I have never seen one to slag off, or as I will never enter a RS, probably ever will.
565 or marantz4300, audio, cambridge, dvd57 or pioneer
