Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Panasonic DMR-EX769 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
LG DRT389H
Sony DVP-FX730
LG RHT497H 160GB
Panasonic DMR-EX98V 250GB
Philips DVP3310
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Panasonic DMR-EZ48
 More...Prices updated November 23rd at 11:30am and include delivery.
Old 12-01-2004, 11:39 AM   #1 (permalink)
Thanks: Gave 4, Got 0
HK DVD25 vs Denon 2900
Ok - simple question - is the Denon 2900 REALLY worth triple the price of the HK ? Granted it's probably better, but £400 better ?
Someone did put me off by saying the HK didnt do true Pal Prog - but converted PAL to NTSC then chucked out PAL Prog.
cant confirm or deny this - so really if it does true PAL Prog (720p ?) then do I really need to spend on the Denon.
BTW - Im going to buy a Sharp Z9000 at the same time to connect to it.
G.
TheBoyGUK is offline   Reply With Quote
Old 12-01-2004, 11:49 AM   #2 (permalink)
Wrong forum - but it is a joint buy with PJ ! <>
Question still stands ! This wont be used on a TV, only the Sharp PJ...
Old 12-01-2004, 1:14 PM   #3 (permalink)
Crocodile JD's Avatar
Thanks: Gave 10, Got 20
I'm sure this post will get moved, but to answer one of your questions, the HK DVD25 does do true Pal PS, as to which is best, if you really are serious about the Denon, get a Demo against the HK.
Croc
Crocodile JD is offline   Reply With Quote
Old 12-01-2004, 2:21 PM   #4 (permalink)
Kramer's Avatar
Thanks: Gave 5, Got 32
Moved to DVD players
Kramer
My personal opinions expressed here are not necessarily those of the AV Forums or other related websites, but you all know that
Kramer is offline   Reply With Quote
Old 12-01-2004, 3:29 PM   #5 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
you really do need to demo side by side on the PJ you are buying and decide if you can see the difference and if it is worth £400
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 12-01-2004, 7:40 PM   #6 (permalink)
Thanks: Gave 1, Got 1
Re: HK DVD25 vs Denon 2900
Pal Progressive scan isn't 720p thats Hi-Def or at least one standard of Hi-Def, a Pal Progressive scan picture is 576p with NTSC Progressive being 480p
rscott4563 is offline   Reply With Quote
Old 12-01-2004, 8:11 PM   #7 (permalink)
Ah yes
You are indeed correct...
Old 12-01-2004, 9:11 PM   #8 (permalink)
It does depend on whther you want to use it as a CD player or interested in SACD or DVD audio. The CD playback is meant to be good. I'm going to demo one this week
Regards
Briggsy
"Enjoy yourself - it's later than you think."
Socrates
Hitachi 500E, Yamaha 640, Denon 2900, KEF 5005, PS2
briggsy is offline   Reply With Quote
2900, denon, dvd25
