Go Back   AVForums.com > Home Entertainment Players and Recorders > Blu-ray and DVD Players > DVD Players
Today's price checkPowered by
Sony DVP-FX730
LG DRT389H
Panasonic DMR-EX769 160GB
LG RHT497H 160GB
Sony DVP-FX730
LG DRT389H
LG RHT497H 160GB
Philips DVP3310
Panasonic DMR-EX98V 250GB
Panasonic DMR-EX79 250GB
Samsung DVD-H1080
Panasonic DMR-XS350 250GB
Sony RDR-HXD995
 More...Prices updated November 22nd at 2:30am and include delivery.
Old 16-12-2003, 7:16 AM   #1 (permalink)
what difference does this make?
I have been looking at prog scan players and looking at tech specs. notice the video DAC spec figures.
On the sony 730 its 108MHZ 12 bit, Yamaha 540 its something like 58MHZ 12 bit. Some like the Tosh SD530 are like the yamaha but say 10 bit also.
What difference is this going to make to the picture.
cuewoz1 is offline   Reply With Quote
Old 16-12-2003, 8:24 AM   #2 (permalink)
RichardA
Posts: n/a
In itself - not a lot !
Remember the signal on a DVD is 8 bit and sampled at 13.5MHz, anything over that is theoretically overkill.
However, the extra bit depth can be useful if the player is doing any proc amp (Processing Amplifier) controls (e.g. Brightness, Contrast, Gamma etc..) when the original signals may get crushed without the extra dynamic range. (Though I would always prefer un-adulterated signals if possible)
The higher sample rate is really only useful where higher output rates are required - Progressive scan requires 27 MHz for example - but is not significant to Standard Definition video.
Numbers on spec sheets can be mis-leading - it's what's done with them that counts! Low numbers done right can look better than big numbers done wrong.
Hope this helps.
Old 16-12-2003, 12:40 PM   #3 (permalink)
Oh I didn't know dvds were 8 bit.
Whats the point dvd player manufactuers makin 12 bit players then?
I will be watching on a panasonic PT200E projector, does this mean it will look different?
difference, make
