Arshad
Since I know you are using the Pioneer 434 plasma and a DVI to HDMI, I suggest you look at the "About HDMI" addendum instructions that came with your plasma. Look at the input signal correlation table. You can input 720P or 1080i but not 768p. As I understand it the plasma number of pixels 1024 x 768 (434) and 1280 x 768 (505) are truly represented by the 720p signal which is then upscaled / downscaled accordingly.
cage2260
