31-12-2006, 9:11 AM
#1 (permalink)
PS3 Blu-ray vs Xbox 360 HD DVD with screen shots
31-12-2006, 9:21 AM
#2 (permalink)
Thanks: Gave 720, Got 847
Re: PS3 Blu-ray vs Xbox 360 HD DVD with screen shots
Calibrating devices isn't this guys forte is it!!
Do everything with excess, even excess
31-12-2006, 9:22 AM
#3 (permalink)
Thanks: Gave 637, Got 142
It clearly shows HD-DVD add on to be better than the PS3 Blurry internal drive
STAR WARS PAINTING FOR SALE
31-12-2006, 9:22 AM
#4 (permalink)
Blurry owner????
31-12-2006, 9:29 AM
#5 (permalink)
Thanks: Gave 420, Got 533
Good link - thanks for posting
31-12-2006, 9:48 AM
#6 (permalink)
Yes it is an interesting read.
31-12-2006, 9:59 AM
#7 (permalink)
Thanks: Gave 948, Got 239
Ditto!
ATB
Max
Toshiba 42Z3030D | Toshiba SD360E | Sky HD | TiVo | Yamaha RX-V100D | Mission Fronts | Yamaha Centre & Rears | Yamaha YST-SW80 Active SUB | Harmony 885 | Dell Dim XP MCE | Dell D620 XP Pro | iPod video 60gb
31-12-2006, 10:14 AM
#8 (permalink)
Thanks: Gave 45, Got 49
without calibrating that is
Never seen MI3 this orange though
A/V Equipment: Playstation 3 (20GB)  , Toshiba HD-XA1, Onkyo TX-SR805B, B&W 685's, Sharp AQuos LC-46X20E
31-12-2006, 11:38 AM
#9 (permalink)
But they are all on the same screen with the same settings ... so why would being calibrated make any difference??? It shows the blurry is exactly that and that they are not exactly the same (ps3 vs xbox 360hd)
If you calibrated the screen to each picture then it wouldnt be a fair test...
31-12-2006, 11:52 AM
#10 (permalink)
Thanks: Gave 12, Got 66
Different source invariably need different calibration, other than that I thought the differences in detail he kept pointing at didn't actually exist, maybe be I'm going blind, maybe higher res screen shots would have helped!
I hadn't realised what a mess the interactivity was on BR at the moment, as Nic has mentioned several times it all looks a bit unfinished...
John.
31-12-2006, 11:53 AM
#11 (permalink)
Thanks: Gave 58, Got 101
 Surely that's the only way to make it a fair test!
31-12-2006, 12:03 PM
#12 (permalink)
Thanks: Gave 87, Got 174
Well all I can say, if I had seen that before buying either of my HD formats, I wouldn't have bothered - none of them looked particuarly good in my view.
No matter which system you purchased, wouldn't you calibrate to get the best picture?
They maybe on the same screen, but they have been connected differently - what was the cable quality? How long was each cable? etc etc
If you connected two AV amps with the same speakers, wouldn't you calibrate each AMP? Wouldn't just connecting them be unlikely to demonstrate their attributes?
I always find it hard to take these sort of things seriously - we are shown stills of HD format saved as 640 x 480 jpegs?
Pete.....an-eye-for-an-eye
31-12-2006, 12:13 PM
#13 (permalink)
Thanks: Gave 56, Got 215
His methods stink, but at least he came to the right conclusion.
The opinions expressed herein are not necessarily those of AV Forums, not necessarily mine, and probably not necessary.
31-12-2006, 12:41 PM
#14 (permalink)
Thanks: Gave 7, Got 82
If he prefers HD, that's cool by me, but why would you possibly try to base a review on screenshots?
SB+, Bel Canto Evo2i, Impulse Ta'us, Coherent system, Audio Technica, Wireworld and Zanash cables, Stillpoints. PS3 with PlayTV, Panasonic AE1000, Thule PR250B processor, Kef 3005 (rears) driven by a Kenwood 3020se.
31-12-2006, 12:55 PM
#15 (permalink)
Thanks: Gave 5, Got 12
I'm sorry but based on those screens there is no way the man in the street would pay for the premium of HD video over standard DVD. The improvement is just not obvious enough. Although i blame the dodgy pics
