Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD and Blu-ray Recorders, Recording and Media
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 20-10-2003, 3:30 PM   #1 (permalink)
Panasonic HS2 & DVD-RAM media - does it take caddy or non-caddy discs???
Well, finally taken the plung for the Panasonic HS2, and it should be with me tomorrow...
Now all I need is some media, so before I buy the wrong type in my lunch hour tomorrow, can someone advise me if the HS2 uses the caddy type or the disc only tupe DVD-RAM?
Thanks in advance...
Thanks also to everyone who posted replies/comments on my other threads asking about the machine - I'd like to especially thank Rasczak for ALL the help with deciding on this one!
TP2K is offline   Reply With Quote
Old 20-10-2003, 3:39 PM   #2 (permalink)
- better still; can anyone recommend an online or High Street supplier for branded media at a reasonable (read: cheap!) cost?
Old 20-10-2003, 4:31 PM   #3 (permalink)
Thanks: Gave 0, Got 2
Not sure about the HS2 but I've just got the E100 and it takes both caddy and none caddy ram disks, I would think that the HS2 should be the same.
Mike
starion is offline   Reply With Quote
Old 20-10-2003, 5:02 PM   #4 (permalink)
CLH
Thanks: Gave 22, Got 20
Caddied or non caddied work fine.
Cheapest I ever found were at the Panasonic online store.
DVD-R (Maxell) can be got for £1.49 in amaray cases at Richer Sounds using the WHF voucher.
CLH is offline   Reply With Quote
Old 20-10-2003, 5:28 PM   #5 (permalink)
Thanks all!
Originally posted by CLH
WHF voucher.
What's that, then?
Old 20-10-2003, 5:29 PM   #6 (permalink)
That'll be What Hi-Fi...
Is it item/quantity specific? ie Could I get just one disc at that price per voucher?
Old 20-10-2003, 6:33 PM   #7 (permalink)
Rasczak's Avatar
Thanks: Gave 489, Got 632
Don't buy too many DVD-RAMs yet! I suggest one or two only as you'll primarily only use them as an 'overspill' for the HDD. Odds are you'll follow the trend of other HS2 users and mainly use DVD-Rs.
Rasczak is online now   Reply With Quote
Old 20-10-2003, 7:03 PM   #8 (permalink)
Thanks; I'd already figured the same!
But since it's due to arrive tomorrow, I wanted at least one RAM disc in hand for my evening of trialing the editing of HDD recordings...
Old 20-10-2003, 8:52 PM   #9 (permalink)
With any luck you'll get at least one free with the machine. I did.
Chrissywis is offline   Reply With Quote
Old 21-10-2003, 9:40 AM   #10 (permalink)
Sorry to go off thread but does the E50 also take the caddied variety?
wilby is offline   Reply With Quote
Old 21-10-2003, 11:09 AM   #11 (permalink)
Rasczak's Avatar
Any Panasonic DVD recorder, including the E50, takes caddied or caddyless disks.
Old 21-10-2003, 12:32 PM   #12 (permalink)
CLH
Yep you could. But why waste a voucher on £1.49 per disc when you can have 20 for under £30! You're going to need them remember!
Old 21-10-2003, 1:31 PM   #13 (permalink)
aaronjon
Posts: n/a
traxdata dvd-r, with slimline slide in case, 99p each
jvc dvd-r, in jewel case, 99p each, from svp.
http://www.blankdiscshop.co.uk/acata...LICK_HERE.html
caddy, discs, dvdram, hs2, media, noncaddy, panasonic
