3.5 million visitors each month
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD and Blu-ray Recorders, Recording and Media
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Is my dvd player faulty? Tony Hancock DVD Players 10 30-12-2008 11:40 AM
Help setting up dvd player mcowl DVD Players 1 30-12-2008 11:24 AM
Assigning 2 DVD players on 876? Keyser-Soze Onkyo Owners' Forum 1 30-12-2008 11:23 AM
Old 30-12-2008, 11:48 AM   #1 (permalink)
Banksie's Avatar
Thanks: Gave 15, Got 14
DVD Ram
Hi, is it possible to copy the video on a dvd ram disc with a pc, as I want to record programs (6 nations rugby) for my Dad in the US but my dvdr will only burn region 2 and I want to be able to burn region free.
Ie copy onto ram disc from tv (dvdr)then rip from ram disc to normal dvd, region free (pc)
Pioneer pdp-436 xde,Toshiba HD-EP30/5,Panasonic DMP-BD35,Sky HD 1TB,Panasonic DMR-EH50 dvdr,Nintendo WII,Yamaha RX-V3800,ACOUSTIC ENERGY AELITE 2,ACOUSTIC ENERGY AELITE CENTRE,ACOUSTIC ENERGY AELITE 1,
Mission ms8 sub,(need upgradeAlways need upgrade!)
Banksie is offline   Reply With Quote
Old 30-12-2008, 11:52 AM   #2 (permalink)
Thanks: Gave 69, Got 527
Re: DVD Ram
whilst your recorder may be locked to region 2 for playback , I dont believe it locks to region 2 on recording , so I do not think that is the issue here
as for transferring to the pc , you need to check if your pc reader or burner can actually read a ram disk , as if it can then I dont see any problem there
the problem as I see it is that you will be recording in pal at 50 hz and he will be trying to play it on ntsc at 60hz , so I suspect its more of a compatibility issue and not a region issue
NO SUPPORT BY PM , THANK YOU !!
ramjet is online now   Reply With Quote
Old 30-12-2008, 12:05 PM   #3 (permalink)
Thanks: Gave 142, Got 1,703
Re: DVD Ram
The discs that DVDR's produce are all region free.
To do anything with your discs on a PC will require a drive that can read RAM discs. Most cannot . They are rare
[ Although cheap and easy to replace with ones that will - unless its a laptop]
As ramjet points out , the big issue will be the video standard.
Dual standard handling capability in TV sets [ Pal /NTSC ] is commonplace and almost universal here but not so common in the US.
Ask yourself : " WHY do I believe what I believe?"
My opinions expressed here are not representative of the opinions of AV Forums.
Gavtech is offline   Reply With Quote
Old 30-12-2008, 12:09 PM   #4 (permalink)
Banksie's Avatar
Re: DVD Ram
thanks for the quick response my recrorder is region free for playback (beside the point) I can read the ram disc but cannot play it and have no idea how to convert the ram file to dvd. I have dvdfab software and roxio software.
Old 30-12-2008, 12:16 PM   #5 (permalink)
Re: DVD Ram
even if you manage to copy the dvd ram disk from the pc reader or burner to your hdd you would still have to re-author it and also try to make it ntsc compatible , so I would suggest you go have a look at videohelp.com and see what can be done after the footage is on your pc hdd
I use a dvd +RW verbatim to transfer footage from my sony 770 recorder into my pc hdd , then I re-author using TMPGenc dvd author and burn a dvdr disk , but I am not trying to make mine ntsc compatible
in the uk we can usually play pal and ntsc , but as gav says in the usa its less likely to be pal compaible so I think you will struggle to produce a disk in ntsc 60 hz mode that would play on his player and tv successfully
dvd, ram
