3.5 million visitors each month
Go Back   AVForums.com > Home Entertainment Players and Recorders > DVD and Blu-ray Recorders, Recording and Media
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Sony rdr-hxd770 help please bigg1970 DVD and Blu-ray Recorders, Recording and Media 19 13-04-2008 12:54 AM
Sony RDR-HXD770 Recording problem please Help :( bigdavekong DVD and Blu-ray Recorders, Recording and Media 1 19-02-2008 2:16 AM
Problem with Sony RDR-HXD770 Stoater DVD and Blu-ray Recorders, Recording and Media 7 19-01-2008 3:11 PM
Sony HXD770/870/970/1070 lock up problem Boostrail DVD and Blu-ray Recorders, Recording and Media 4 04-01-2008 8:56 AM
Sony HXD770? rcrm4444 All-in-one Systems 1 17-12-2007 5:44 PM
Old 27-10-2008, 5:47 PM   #1 (permalink)
Problem playing DVD+RW on Sony RDR-HXD770
Hi, My DVD player/recorder was recommended to me so I bought it. It says that it can play DVD+RW and it does. However, whenever I erase/format/record on one of these DVD+RW for a second time, I always seem to get the message 'cannot play disc' on the machine. If I put it into my PC, it plays OK. This makes the purpose of a RW disc a waste of time. Can anyone suggest why its doing this ?
boltonwanderer is offline   Reply With Quote
Old 27-10-2008, 6:02 PM   #2 (permalink)
Thanks: Gave 142, Got 1,703
Re: Problem playing DVD+RW on Sony RDR-HXD770
Are you formatting the disc on the PC or the machine?
Ask yourself : " WHY do I believe what I believe?"
My opinions expressed here are not representative of the opinions of AV Forums.
Gavtech is online now   Reply With Quote
Old 27-10-2008, 6:21 PM   #3 (permalink)
Hi, the first time I used it (new DVD+RW), I burnt a tv show to the DVD using my PC software and it played on my DVD player. The second time I used it, my DVD burning software asked if I wanted to erase it before recording, I selected yes, then it burnt my next tv show (which now wont play).
I can only guess that the format now is different to when it was a blank (new) DVD+RW ???
Old 27-10-2008, 7:50 PM   #4 (permalink)
Thanks: Gave 69, Got 527
the problem here is that you are confusing formatting on the sony with formatting on the pc , you assume that as the word formatting is used they are both the same
they arent !!
nescafe coffee is not the same as maxwell house coffee and neither are the same as gold blend coffee !!! now maybe you get it ?
if you format and use dvdrw disks on the sony and only use the sony for reformatting you can use them over and over on the sony and nowhere else
if you use the pc for formatting then you can only use them on the pc , but they may play on the sony
so mark them accordingly as pc or sony and you will find you can re use them on the appropriate device
once they are formatted on the pc the sony will not re-use them
NO SUPPORT BY PM , THANK YOU !!
ramjet is online now   Reply With Quote
dvd, playing, problem, rdrhxd770, sony
