Thanks ramjet,
I have burnt several "fimeware CDRs" and tried with a CD-RW.
I burnt them "my way" at first then using the 2 methods provided on the special topic on the forum
That's later that I found that the unit couldn't read CDs anymore : no mp3 CDR, no commercial CDs, absolutly nothing on CD.
The drive spins/click/spins/click ... and it never writes anything more than load ... then ejects the CD saying it is not compatible.
I assume the drive might be CD-dead ?
Isn't it possible to replace the drive ? I did it several times on old Mac laptops. I suppose that it is even simpler on a Sony recorder. And the Sony regional repair unit is at 10 minutes from my home. Years ago I had bought them Sony spare parts, the only problem is that they are pretty expensive.
I have no DVD+RW but DVD-RWs.
I'll try that but I have no idea on how to create an iso DVD-RW with the upgrade file ... on a Mac with Toast ?
