Major problem with DS Lite/3rd party charger
Old 14-02-2009, 4:36 PM   #1
2,213, Level: 10
Points: 2,213, Level: 10 Points: 2,213, Level: 10 Points: 2,213, Level: 10
Activity: 2.8%
Activity: 2.8% Activity: 2.8% Activity: 2.8%
Thanks: Gave 7, Got 2
Right Guys here’s my dilemma.
I work away from home a lot; when I came home I discovered I’d left my charger at work. Knowing I’d not get my charger for at least 2 weeks I bought a charger supposedly suitable for the DS lite, plugged it in and left it charging I thought.
Next day my new R4 card arrive from Memory Bits. Anyway, downloaded firmware onto SD card inserted SD card into R4 card and then into DS Lite switched on and nothing my DS doesn’t work at all now.
I’m back at work and tried the proper charger still nothing.
<snip>
My dilemma is, has the cheap charger knackered the DS or has the is it the R4 card.
Thoughts anybody.
Last edited by G a f f e r; 14-02-2009 at 8:57 PM. Reason: no need to link to a separate site with the exact same topic, it's sufficient to ask here ;)
Old 14-02-2009, 6:02 PM   #2
Illustrious Member
Badger0-0's Avatar
43,318, Level: 50
Points: 43,318, Level: 50 Points: 43,318, Level: 50 Points: 43,318, Level: 50
Activity: 85.5%
Activity: 85.5% Activity: 85.5% Activity: 85.5%
Thanks: Gave 467, Got 1,881
Re: Major problem with DS Lite/R4
You haven't given enough info.
Does the DS power up at all?
If it doesn't, the charger has probably knackered it.
If it powers up and you're seeing an error or something, I'd put money on it being a firmware problem.
In which case have you double checked the E-mail Memorybits sent you about the firmware when you made the order?
I've seen loads of people with similar problems and it's invariably because they haven't followed the instructions properly.
Old 14-02-2009, 6:04 PM   #3
Illustrious Member
Badger0-0's Avatar
43,318, Level: 50
Activity: 85.5%
Oh, if it does power up, try booting it with a proper game in it.
That will tell you straight away if it's bricked.
Old 14-02-2009, 8:55 PM   #4
G a f f e r's Avatar
16,025, Level: 30
Points: 16,025, Level: 30 Points: 16,025, Level: 30 Points: 16,025, Level: 30
Thanks: Gave 192, Got 341
Re: Major problem with DS Lite/3rd party charger
Sounds like this is an issue with the 3rd party charger rather than the R4 so I'll keep it separate from the R4 thread for the time being (title amended).
3rd Party chargers tend to be quite shoddy and definitely not recommended for use ime. When they charge using incorrect current/voltage/spiking, they can blow an internal fuse on the DS which results in an unresponsive console.
The link given shows you how to repair that fuse.
If it ends up being faulty R4 firmware after all (unlikely if you did as recommended and downloaded form the R4 parent company site), then I'll merge this into the R4 thread when/if confirmed .
Old 14-02-2009, 9:19 PM   #5
Illustrious Member
Badger0-0's Avatar
43,318, Level: 50
Activity: 85.5%
That's a great link, Gaffer if it has blown a fuse
I've a MAJOR problem with the following line though mate;
An alternate method is to simply solder across the two terminals
That would allow amps to go through, as opposed to the fractions of that, that are required to blow the fuse.
I might be being pedantic, but if someone was to stupidly overload the DS again, that's got to be guaranteed fatal, imo.
Just a thought
Old 15-02-2009, 8:03 AM   #6
2,213, Level: 10
Activity: 2.8%
sorry guys been at work.
The DS dose not power up at all, with the charger on the wee red light flashes on once then nothing.
The R4 software was downloaded from here .
Old 15-02-2009, 12:50 PM   #7
Illustrious Member
Badger0-0's Avatar
43,318, Level: 50
Activity: 85.5%
Probably blown a fuse then, as Gaffer says.
At least it's hopefully repairable
Old 15-02-2009, 1:09 PM   #8
4,482, Level: 15
Points: 4,482, Level: 15 Points: 4,482, Level: 15 Points: 4,482, Level: 15
Thanks: Gave 16, Got 97
There is an ebay shop that sells both internal fuses for a DS for about £3 if I recall correctly.. .. .. .. a better solution?
Old 15-02-2009, 1:39 PM   #9
Illustrious Member
Badger0-0's Avatar
43,318, Level: 50
Activity: 85.5%
I'd say so
Powered by
 Latest popular product prices
Peppa Pig: The Game
5 prices from
 £9.95 Click to show/hide the offers
Peppa Pig: The Game
5 prices from
LEGO Harry Potter: Years 1-4
9 prices from
 £11.99 Click to show/hide the offers
Let's Draw
8 prices from
 £9.99 Click to show/hide the offers
9 prices from
Let's Draw
8 prices from
Peppa Pig: Theme Park Fun
5 prices from
 £11.58 Click to show/hide the offers
5 prices from
 Updated February 12th at 11:30pm. Prices include delivery.
