DS Wifi connection Problems HELP NEEDED
Old 05-12-2008, 8:42 PM   #1
2,643, Level: 11
Points: 2,643, Level: 11 Points: 2,643, Level: 11 Points: 2,643, Level: 11
Red face DS Wifi connection Problems HELP NEEDED
I am having problems connecting my DS via my BUFFALO WBMR-G54 ADSL router. The DS can find the access point easily enough but I keep getting a 51300 error code. I have checked the nintendo website and it just tells me to check the settings. I have got WEP encryption but I have entered the key correctly (it doesn't tell me its incorrect when I input it). Its really starting to get on my T*ts. help
Old 05-12-2008, 8:53 PM   #2
FATFINGERS73's Avatar
5,515, Level: 17
Points: 5,515, Level: 17 Points: 5,515, Level: 17 Points: 5,515, Level: 17
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 199, Got 113
Re: DS Wifi connection Problems HELP NEEDED
Check you have the latest firmware on your router.
Also you can't use a passphrase as your WEP key, you must enter the actual WEP code.
Hope that helps.
Old 05-12-2008, 9:02 PM   #3
2,643, Level: 11
Checked the firmware, everything seems fine. Without wanting to give too much away. The WEP key I've used consists of 7 letters (A-H) and 3 Numbers (0-9).
Thanks for the swift response BTW
Old 05-12-2008, 10:04 PM   #4
kdc kdc is offline
kdc's Avatar
4,597, Level: 16
Points: 4,597, Level: 16 Points: 4,597, Level: 16 Points: 4,597, Level: 16
Thanks: Gave 96, Got 114
I had a problem with my DS and wep keys, it just didnt like it... try (temporarily) turning wep encryption off so your wifi is open. if the DS connects you know it doesnt like the WEP.....
My solution was to turn access control on so only the MAC address of devices I specify can connect, this sounds fiddly but was a lot simpler than encryption...
Old 06-12-2008, 12:51 PM   #5
G a f f e r's Avatar
16,025, Level: 30
Points: 16,025, Level: 30 Points: 16,025, Level: 30 Points: 16,025, Level: 30
Thanks: Gave 192, Got 341
Some people have tried this which might work....use a 13 character password.
Sounds odd but some devices can be a bit "picky" when it comes to connecting to things.
If not, I definitely do not recommend turning all encryption off. You might want to try going through the manual settings route and input all entries yourself (just to make sure they're all correct).
Finally, try changing your router to broadcast on channel 1, 6 or 11 (the only truly 'discrete' channels ---- all the others overlap with adjacent ones). Again, a long shot but worth a try.
Here is an explanation of error 51300 btw .
Old 29-12-2008, 12:46 PM   #6
cas398's Avatar
6,038, Level: 18
Points: 6,038, Level: 18 Points: 6,038, Level: 18 Points: 6,038, Level: 18
Thanks: Gave 201, Got 192
This is how I connected my Wii to the router. I'm just wondering if you know how I can find my DS's MAC address so I can do the same thing instead of messing about with WEP/router setting which I know little about.
If that is what you mean.
Old 29-12-2008, 8:52 PM   #7
Tetlee's Avatar
57,913, Level: 58
Points: 57,913, Level: 58 Points: 57,913, Level: 58 Points: 57,913, Level: 58
Activity: 24.0%
Activity: 24.0% Activity: 24.0% Activity: 24.0%
Thanks: Gave 1,336, Got 1,898
Originally Posted by cas398 View Post
I'm just wondering if you know how I can find my DS's MAC address so I can do the same thing instead of messing about with WEP/router setting which I know little about..
I had to find this for a friends DS recently in order for them to connect to their router. If I'm not wrong you do need a WiFi enabled game in order to be able to find it(bit odd but I didn't have any luck without the game),. Within the game menu, go to the Nintendo Wi-Fi Connection Setup, select "options" followed by "system Information" and the MAC address should be displayed there.
cas398 (30-12-2008)
Old 30-12-2008, 1:20 PM   #8
cas398's Avatar
6,038, Level: 18
Cheers. I stuck the MAC address in the router but it's still not having it.
Don't know if I should change to WEP
Old 30-12-2008, 1:23 PM   #9
4,482, Level: 15
Points: 4,482, Level: 15 Points: 4,482, Level: 15 Points: 4,482, Level: 15
Thanks: Gave 16, Got 97
If you are not using encryption then it won't help. If you are using WPA or WPA2 then it will solve your connection issues as the DS ONLY supports WEP encryption.
Don't forget that changing the type of encryption will mean that you have to reconnect all of your other devices
cas398 (30-12-2008)
Old 30-12-2008, 1:52 PM   #10
cas398's Avatar
6,038, Level: 18
Cheers. My router is set to WPA.
Guess I'll give it a go.
Old 13-01-2009, 6:53 PM   #11
Thanks: Gave 428, Got 365
Did it work? As im having the same problem and mine is set to WPA-PSK, Thanks
Old 14-01-2009, 6:45 PM   #12
cas398's Avatar
6,038, Level: 18
I had second thoughts, don't know if downgrading (or what I believe is downgrading) my security settings and having to re-connect my network devices is worth it.
Old 28-01-2009, 2:12 PM   #13
cas398's Avatar
6,038, Level: 18
I did it this afternoon and got it working. It was fairly straight foward and didn't take long at all. Just generated a WEP code and, entered it in the DS and let it connect automatically. I'd aslo recommend taking the DS online, it's more fun than I expected .
Old 10-02-2009, 10:31 PM   #14
1,025, Level: 7
Points: 1,025, Level: 7 Points: 1,025, Level: 7 Points: 1,025, Level: 7
Unhappy Re: DS Wifi connection Problems HELP NEEDED
Please please help b4 i drop kick my DS out off the window. I have a Belkin F5D9630-4A and cannot for the life of me get it to connect. I did auto search access point and it found it straight away but when i test connection i keep getting 52100 error. I manually entered all my ip's and dns's but no avail. I have no security enabled on router so no need for wep/wap key . im at the end of my tether, or do i just go out and buy the USB wifi connector???
Old 10-02-2009, 11:41 PM   #15
cas398's Avatar
6,038, Level: 18
Have you checked this thread?
http://www.avforums.com/forums/ds-on...ml#post8829889
This post should solve your problem I think.
Try this.
Don't go to 'Search for an access point'.
Go to 'Manual setup'.
Enter the SSID - name of your network (as it would be displayed on the access point list).
Enter the WEP key. (I suppose you can leave this blank if it's an unsecure network, or even better enable WEP )
Enable Auto-obtain IP address.
Enable Auto-obtain DNS.
That should do it I think.
Failing that try entering the MAC address of the DS into your router.
The thing about entering you IP address is it's probably looking for a unique address so it doesn't conflict on the network. Not the address of your router. Auto-obtain should sort that out.
Old 18-10-2009, 4:01 PM   #16
1,380, Level: 8
Points: 1,380, Level: 8 Points: 1,380, Level: 8 Points: 1,380, Level: 8
can somebody help me??!! every time i search for an access point, it finds my modem, but when i type in the 10-digit WEP key, i test the connection and i get error code 51300. i also tried the 13-digit key, but that didn't work either somebody help,
Powered by
 Latest popular product prices
Peppa Pig: The Game
6 prices from
 £8.95 Click to show/hide the offers
Peppa Pig: The Game
6 prices from
LEGO Harry Potter: Years 1-4
10 prices from
 £11.95 Click to show/hide the offers
Let's Draw
8 prices from
 £9.99 Click to show/hide the offers
10 prices from
Let's Draw
8 prices from
Sonic Classic Collection
8 prices from
May's Mysteries: The Secret Of D...
6 prices from
 Updated February 13th at 10:30pm. Prices include delivery.
