DS is bust after i changed the case. Help
Old 24-08-2009, 1:10 PM   #1
6,588, Level: 19
Points: 6,588, Level: 19 Points: 6,588, Level: 19 Points: 6,588, Level: 19
Thanks: Gave 516, Got 76
Hi all, after the original case cracked ion the hinges, i bought a replacement and swapped it all over. It went very smoothly, but when i push the power button on the light lights up the top screen flashes and then nothing.
Any ideas on what i might have done? I was thinking maybe the ribbon connector was put back slightly out of alignment maybe?
Thanks for any help.
Old 25-08-2009, 12:29 AM   #2
4,482, Level: 15
Points: 4,482, Level: 15 Points: 4,482, Level: 15 Points: 4,482, Level: 15
Thanks: Gave 16, Got 97
Re: DS is bust after i changed the case. Help
IIRC it sounds like you've blown one of the internal fuses. If you can solder then they can be easily bypassed (with wire) or replaced (about 50p each on ebay).
I think there was a thread about it somewhere here but I can't remember where .. .. .. there may even be diagrams and links for parts if you can find it.
deefadog (25-08-2009)
Old 25-08-2009, 7:00 AM   #3
6,588, Level: 19
Thanks, yes i did read about the fuse. i'll look into it
Old 28-08-2009, 8:15 AM   #4
2,507, Level: 11
Points: 2,507, Level: 11 Points: 2,507, Level: 11 Points: 2,507, Level: 11
Activity: 0.2%
Activity: 0.2% Activity: 0.2% Activity: 0.2%
Thanks: Gave 5, Got 6
I had the same thing on my sons , it was the ribbon for the top screen .
I hadnt clamped it back in correctly .
deefadog (28-08-2009)
Old 28-08-2009, 8:54 AM   #5
6,588, Level: 19
Thanks stumpy
I have encounter a new problem, one of the tri screws is rounded - must have done it when i put it back in. Ay ideas on how to get this out???
Old 28-08-2009, 10:07 AM   #6
tylerjosh's Avatar
5,131, Level: 16
Points: 5,131, Level: 16 Points: 5,131, Level: 16 Points: 5,131, Level: 16
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 288, Got 323
Can 95% confirm that it will be the the ribbon cable that joins the top screen to the main board, its really tricky to get it connected and working.
The cable must be seated fully into the ribbon connector, it drove me mad for 45 mins lol
got there in the end.
Regarding the rounded screw can u get to it or is it in one of the ones's in the outer case that drops into the deeper hole?
If it is then have no idea waht to do there other wise u might be able to grind the screww head of with a dremel type drill.
My mate had to do this as his did exactly the same thing but was in the battery compartment and was able to remove the screw head.
Good luck
Old 28-08-2009, 1:16 PM   #7
6,588, Level: 19
Thanks, yes unfortunately it is the one in the main body that's deep - I'll try the dremell
Powered by
 Latest popular product prices
Peppa Pig: The Game
5 prices from
 £9.95 Click to show/hide the offers
Peppa Pig: The Game
5 prices from
LEGO Harry Potter: Years 1-4
9 prices from
 £11.99 Click to show/hide the offers
Let's Draw
8 prices from
 £9.99 Click to show/hide the offers
9 prices from
Let's Draw
8 prices from
Peppa Pig: Theme Park Fun
5 prices from
 £11.58 Click to show/hide the offers
5 prices from
 Updated February 12th at 7:30pm. Prices include delivery.
