Vogels EPC-4010 ceiling mount & Sanyo Z3 conflict!
I just received my Vogels EPC-4010, and it doesn't have the right size fittings for the Z3. The arms that connect to the Z3 only have a 5mm hole for the connecting bolts, and unfortunately the Z3 requires M6 bolts.
Thanks to the forum I had heard that the bolts included with the Vogels 4010 might not be the right size for the Z3 (I bought some M6 bolts in advance), but what I didn't realise was that the mount would need the holes on the arms widening to accomodate the M6 bolts. This shouldn't be too difficult to do, but I think it defeats the point of spending £80 on something that is horrendously overpriced and doesn't fit out of the box.
Has anyone successfully ceiling mounted a Z3 with a Vogel's EPC-4010? Or should I just return it and look for another alternative? I got the EPC-4010 for £80 inc. delivery from AVRabbit, and I really don't want to spend anymore than that on a ceiling mount, so I think I'll have to leave the LMPs @ £100 and consider Ebay or DIY alternatives.
