AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > DLP, LCD and D-ILA Projectors
LinkBack Thread Tools Display Modes
Old 28-10-2003, 12:21 AM   #1 (permalink)
Thanks: Gave 3, Got 8
Question PLVZ2 Connection Options?
As one of the few people waiting for their new Z2 to arrive, I have a couple of questions of connections:-
1) As there is no VGA connector, what is the best option for connecting a VGA device? Is it a VGA - DVI (which one, by the way? I? D?). Or a VGA - component?
2) Is it better to have the playback device near to the PJ, and have a longer audio cable to the amp/speakers etc? (eg, optical digital sound cable), than having the longer dvi, or component etc cables?
dean randle is offline
Old 28-10-2003, 7:11 AM   #2 (permalink)
nunew33's Avatar
Location: Lytham St Annes, where people are put out to grass and die!!
Thanks: Gave 0, Got 2
1) DVI - I. I did a DVI FAQ a few days ago with everthing icould find. You need a vga to DVI converter (about £15)
2) there is an issue with DVI length being > 7.5 metres(look at faq). Some people say they have done longer runs, but I didnt risk it, I put in VGA cable. Not sure which is best. Set up is kit at front and 10m cables channelled in ready for a Z2
Sanyo Z2, DRH Screen, Marantz 5200, Freshly dead Sony DVD 735 RIP, Tosh VCR 753, Pace digibox, Mission Cinema 7, Sony PS2. OFA Mosaic, Tosh RDXS32 , Canon MVX460 ,Canon S3, empty wallet .
nunew33 is offline
Old 28-10-2003, 10:27 AM   #3 (permalink)
Advertiser
Thanks: Gave 16, Got 47
Extron do a range of boosted DVI cables up to 75 feet but they are rather expensive (the 75ft retails for £871+VAT).
Ken Davies
Ivojo Multimedia Ltd.
http://interactive-av.co.uk
Ivojo is offline
Old 28-10-2003, 11:13 AM   #4 (permalink)
ouch........ thats going to hurt a bit! I guess I might manage to get away with 5m....... what is the difference betwee I and D? Presumably one is digital ad one is analogue? Lindy have cables of 5m odd at £30 or so, is this good enough?
ad
buns is offline
Old 28-10-2003, 11:32 AM   #5 (permalink)
Advertiser
I wouldn't have thought that there's going to be any problem with 5 metres and Lindy are cheap enough that it's worth a go. If you do have problems then try re-routing the cable and normal data cable advice applies (keep away from mains cables etc.)
DVI-D is digital only, DVI-A is analogue only, DVD-I is both.
Ken Davies
Ivojo is offline
Old 28-10-2003, 11:40 AM   #6 (permalink)
please excuse my ignorance on this...... I am going to use the dvi out from my radeon 7500...... which variety of dvi cable should i get?
And out of interest, how can a digital video interface connector be refferred to as analogue!? Isnt that a contradiction!
thanks
ad
buns is offline
Old 28-10-2003, 11:48 AM   #7 (permalink)
Advertiser
Yes and no. I would think the analogue side of things is just for backwards compatibility. Remember the DVI was origionally developed for computer use and having an analogue facility means that a DVI output can still be used (via an adaptor or appropriate cable) with a RGBHV (15 pin d-sub, 5*BNC, 5*RCA etc.) analogue input display.
Ken Davies
Ivojo is offline
Old 28-10-2003, 12:37 PM   #8 (permalink)
so what type of cable do I want for between my radeon 7500 and the z2?
thanks
ad
buns is offline
Old 28-10-2003, 12:57 PM   #9 (permalink)
Dutch's Avatar
Thanks: Gave 201, Got 95
Hi buns,
A dual link DVI-D to DVI-D would be what you want. Lindy's cables are very good and also reasonably priced.
Steve
Sky HD, Pioneer LX5090, BDP-05FD, 757Ai, AX4ASi, Toshiba HD-XA1, XE1, Sony HXD910, Kef iQ7SE (front), Kef iQ6C (centre), Kef Q55 (rear), SVS 2039PC+, Harmony 1000, with Kimber, Supra, Molex and BlueJeans cables
Dutch is offline
Old 28-10-2003, 1:22 PM   #10 (permalink)
Thank you very much Mr Dutch!
ad
buns is offline
Old 28-10-2003, 4:31 PM   #11 (permalink)
So, I would be in trouble needing a 15m run then?
Anyone know what my best and cheapest options would be - I was going to run 4x phono component leads for the DVD player, but I also have a Tivo and PC that I would want to connect.
The problem is that we're about to decorate and the wiring will be behind coving, maybe before I get the PJ....
Woz! is offline
Old 28-10-2003, 5:15 PM   #12 (permalink)
nunew33's Avatar
Woz, I am using VGA with a vga DVI converter at the end tpo get round log cable runs.
This means I can use 3 componant for DVD, composite for VCR (rarely used), s-video for camcorder and a scart to VGA for sky (assume you would use RGB to vga for Tivo).
Hope this is of use.
Ive seen some us sites with a DVI splitter, splitting into VGA ad DVI-D. This may be a possible future purchase and Ill simply have to have a DVI cable visible, with the DVI source at the rear of the room rather than the front. But seeing as I have no DVI sources this ist an issue
Caveat: I am just learning about DVI so please be kind if Ive misunderstood things
nunew33 is offline
Old 28-10-2003, 8:01 PM   #13 (permalink)
Oooh, cheers, that's really helpful!
What length of run are you doing? is it 15m or more?
I was just getting horrified at the option of getting an RGB to Component converter after I'd seen that I was looking at the best part of £150.....
Woz! is offline
Old 28-10-2003, 8:18 PM   #14 (permalink)
whats about this
ad
buns is offline
Old 28-10-2003, 9:16 PM   #15 (permalink)
nunew33's Avatar
Woz,
Im doing 10m, got 4 rca leads,vga and svid from vcd trading for about £90. Anticipating £12 for DVI/VGA and £20 for scart to VGA and scart splitter/amp for £30 which I will get when Z2 arrives.
For all leads my budget was £150
nunew33 is offline
connection, options, plvz2
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
