I thought it would be good to share the build process of my Rythmik DS12 with you lot, and ofcourse appreciate your comments along the way.
This is a servo sub, employing 'similar' technology and principals as Velodyne DDs.
I have been reading up on subs on this forum for a while, and subsequently became very close to buying a BK Monolith / SVS. But I didn't, for these reasons:
- I don't need huge* SPL, and HT is secondary to music reproduction for me
- I wanted something that wasn't too big, but didnt want to trade much extension
- Always wanted to do a DIY speaker project.
- The best 'quality' bass I could afford.
The last point may be slightly contentious, as I have never heard an SVS ultra, BK monolith or indeed a Rythmik. Like many people here, I have had to put my faith in members on various forums, and hearing favourable comments about the Rythmik over the likes of SVS and JL, (not forgetting Ilkka's sub tests) I decided to take the plunge and order the kit from:
Rythmik Audio 12" servo subwoofer " DS1200 Custom Installation subwoofer
Delivery takes 4-6 weeks, and as I have recently ordered it, I'm in for a long wait. At this point I should credit 'milesr3' with his excellent thread and link to his build -
http://www.avforums.com/forums/home-...ealed-56l.html , great for reference - thanks!
So to ease the pain of waiting so long, my build commenced.
Plans are gleaned from Rythmiks website, the 2 cubic ft (56L) enclosure to suit the 12" driver and 370W servo amp.
I had originaly decided to rotate the entire enclosure to create a forward firing design, and relocate the amp plate to opposite the driver. I built a 3D model to proof it first -
After messing around with the cut 18mm MDF sheets, I reverted to the original plans for a downward firing version...
So, first off the panels were and braces were cut. Sorry about the picture quality!
Then the gluing process begins. Screws could be used to hold the glued panels together but wouldn't really give you more in terms of strength, this is just stuck using PVA and heavily clamped.
Note extra corner beading (above) for added strength.
Also the 4th side panel is glued on (not shown)
The enclosure has been very easy to make so far, there are just a couple of edges that sit proud at the top that will require sanding / plaining back so the last panel (top) can fit on flush...
Then comes the major sanding and addition of legs. The corners will eventually be routed too. Not too sure about putting spikes on the feet though
I will update this thread with more pics as and when I have made more progress
Ash
