New Diy Sub in the works
Old 12-07-2007, 10:14 AM   #1
3,995, Level: 14
Points: 3,995, Level: 14 Points: 3,995, Level: 14 Points: 3,995, Level: 14
Thanks: Gave 7, Got 9
Im my ever long quest for amazing bass without breaking the bank i have decided to re-build my current diy sub into something bigger and better.
As it stands my current sub is basically a bk monolith with a slightly larger internal volume, this sub was great for a couple of months until i heard a freinds diy sub and my jaw hit the floor.
What im planning to do is more of a sideways step rather than a full blown upgrade. What im planning on doing is going from 1 monolith driver to 2 drivers and re-building in a sonotube style enclosure. Internal volume will have to be up somewhere around 180-250 ltrs which isn't as bad as it sounds as a sonotube takes up little floor space.
It will be ported around 18hz, if this design all goes to plan then i should be greeted with some serious levels of bass to statisfy my needs!
atb,
Greg
Old 19-07-2007, 8:07 PM   #2
4,422, Level: 15
Points: 4,422, Level: 15 Points: 4,422, Level: 15 Points: 4,422, Level: 15
Thanks: Gave 18, Got 17
Re: New Diy Sub in the works
sounds like a good plan how are you going to mount the 2 drivers and port?
dave
