Building a DIY sub, anyone tried the CPC active 250w panel amp?
Old 15-09-2006, 8:16 PM   #1
6,692, Level: 19
Points: 6,692, Level: 19 Points: 6,692, Level: 19 Points: 6,692, Level: 19
Thanks: Gave 20, Got 13
Guys,
I'm building a sub for ultra discreet bedroom setup, so I can fit it under the bed. I've got an Adire Shiva hanging around that I am going to use, and I've designed a nice box using Bassbox Pro. I've gone for an amp panel from CPC to power it, but just wondered if anyone here had tried one?
I've done a search but came up with nothing, which seems odd, as it looks like very good value for money at around £100 for 250w RMS.
Link if anyone is interested:- http://cpc.farnell.com/jsp/endecaSea...sp?sku=LS01562
Old 16-09-2006, 7:03 AM   #2
Conspicuous Member
18,418, Level: 32
Points: 18,418, Level: 32 Points: 18,418, Level: 32 Points: 18,418, Level: 32
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 263, Got 636
Re: Building a DIY sub, anyone tried the CPC active 250w panel amp?
The technical details are all rather vague.
We like BK.
http://www.bkelec.com/Modules/Sub_Bass.htm
Old 16-09-2006, 7:30 AM   #3
6,692, Level: 19
Yeah, but it's cheap!
It looks OK in the flesh, quite a hefty power supply, and a useful function if using the high level inputs, it has high level outputs crossed over at 120Hz. Not that I'll use that though.
I'll give it a go, the main reason for going for this one was the price. I'm trying to keep the cost to an absolute minimum.
Old 16-09-2006, 7:43 AM   #4
Conspicuous Member
18,418, Level: 32
Activity: 5.7%
It lacks a fully adjustable crossover frequency (unless I missed something)
If you can't adjust the frequency you can't match the sub to your speakers.
Old 16-09-2006, 7:52 AM   #5
6,692, Level: 19
Crossover frequency is variable from 40Hz to 160Hz.
It's actually a bit different from the one on cpc's website, there is also a switch for power on/auto/off.
Old 16-09-2006, 7:54 AM   #6
Conspicuous Member
18,418, Level: 32
Activity: 5.7%
Where did you get this information from?
Old 16-09-2006, 10:45 AM   #7
6,692, Level: 19
By looking at it, I've already bought it, I can post a better picture if it's of any interest. Just got back from B&Q with my MDF, so it's all ready to start building.
Old 16-09-2006, 11:10 AM   #8
Conspicuous Member
18,418, Level: 32
Activity: 5.7%
Righto. Get cracking then!
We shall want pictures and an REW response graph at the very least.
Old 16-09-2006, 11:41 AM   #9
IronGiant's Avatar
25,220, Level: 38
Points: 25,220, Level: 38 Points: 25,220, Level: 38 Points: 25,220, Level: 38
Activity: 29.4%
Activity: 29.4% Activity: 29.4% Activity: 29.4%
Thanks: Gave 2,347, Got 4,999
More technical specs here:
http://cpc.farnell.com/jsp/endecaSea...cpc/260654.xml
I wouldn't swap it for my BSBP 100 though .
Old 16-09-2006, 3:47 PM   #10
7,119, Level: 20
Points: 7,119, Level: 20 Points: 7,119, Level: 20 Points: 7,119, Level: 20
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 6, Got 61
It's a very common plate amp used sucessfully by lots of people, you'll also find it at Partsexpress and Jaycar amongst others.
Old 16-09-2006, 4:59 PM   #11
6,692, Level: 19
Any particular reason why?
Old 16-09-2006, 6:27 PM   #12
IronGiant's Avatar
25,220, Level: 38
Activity: 29.4%
"Quote:
Any particular reason why?"
Don't let me put you off that panel, it looks really nice, that wasn't my intent. Avanzato has said that lots of people use it successfully.
However,
It costs about the same as the BSBP 100 but is 2.5 times more powerful. And has more features such as satellite output. I never turn my 100W amp up beyond a quarter power so I don't need 250W and I don't need satellite outputs.
So my assumption is that a lower powered amp with less features from a producer I know well "might" give better sound quality than an amp that cpc farnell can't tell us who made it.
I certainly haven't compared them, so my comment was only meant as "I like what I have"
Dave
Old 16-09-2006, 6:59 PM   #13
6,692, Level: 19
I really just meant was there anything particularly you liked about the BSBP amp. To be honest, I don't need high level outputs, and I don't have my sound very loud either, the only reason I chose the CPC one is price.
The instructions and box say it's made by MCM Custom Audio, www.mcmelectronics.com but theres not much info there, I guess that's just where CPC source them.
Old 16-09-2006, 9:27 PM   #14
IronGiant's Avatar
25,220, Level: 38
Activity: 29.4%
Whydo I like it,
I completely screwed up (literally) when installing some spikes after I made the sub. The drill bit snagged the wadding that then got entangled in the heavy weight cable I had hooked up between the driver and amp panel. The PCB on the amp panel was nearly bent in half when I opened it up to see what the damage was...
It worked perfectly despite my attempt to break it and has done so for several years since.
So, I like the build quality
I'm sure your panel will be fine, don't test it like I did mine :-)
Dave
Old 16-09-2006, 9:30 PM   #15
Conspicuous Member
18,418, Level: 32
Activity: 5.7%
Sorry, but I had to laugh.
Old 16-09-2006, 10:01 PM   #16
Paul Smith's Avatar
4,562, Level: 16
Points: 4,562, Level: 16 Points: 4,562, Level: 16 Points: 4,562, Level: 16
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 24, Got 51
The Adjustable EQ on the CPC panel certianly puts it ahead of the standard BK panel for me,
Together with the cheaper price and extra power and I can't see why you wouldn't want to choose the CPC panel .
Paul.
