Originally Posted by stuman i would love to, but im using a naim audio nait 5i. only output is high-level stereo. so would have to reduce it down to a low-level signal, then chop off the 80Hz+ boost 6db at the -6db mark then i could finally amp it. ive just noticed that the Fi Q18 would only want 200W rms, does that mean that without the power upgrade i could get away with the 300 watt plate amp? |
The 300 watt amp plate would be fine, although the driver could handle more if you wished.
You dont need to convert the signal to a low level one, but you would need some kind of filter to get the sub to operate only the range you want. A bfd would do the job, or you could add a crossover into the sub itself, but that will start to make things complicated.
A plate amp is probably your best bet in your circumstances though, and is certainly the easiest solution.
