Quieter fans for Behringer amps
Old 09-11-2009, 12:32 PM   #1
11,342, Level: 25
Points: 11,342, Level: 25 Points: 11,342, Level: 25 Points: 11,342, Level: 25
Thanks: Gave 24, Got 43
Hi there,
Can someone point me in the direction of getting a quieter fan for the behringer amps. I would prefer one that I don't have to solder and that I can just unplug the old one and plug in the new one because of the warranty.
Adam, I just read your post on the hometheatershack forum. Did you have to cut the wire and re fit the plug back on.
http://uk.rs-online.com/web/search/s...duct&R=2991403
cheers
Graham
Old 09-11-2009, 3:37 PM   #2
Conspicuous Member
Moonfly's Avatar
24,796, Level: 38
Points: 24,796, Level: 38 Points: 24,796, Level: 38 Points: 24,796, Level: 38
Activity: 22.8%
Activity: 22.8% Activity: 22.8% Activity: 22.8%
Thanks: Gave 355, Got 1,104
Re: Quieter fans for Behringer amps
Behringer EP2500/4000 'Silent Fan Upgrade'
Old 09-11-2009, 4:30 PM   #3
Conspicuous Member
AngelEyes's Avatar
29,366, Level: 41
Points: 29,366, Level: 41 Points: 29,366, Level: 41 Points: 29,366, Level: 41
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 324, Got 786
You won't find any suitable fans with the right connector I am afraid. If you do get lucky, please share as I don't know anyone who has.
Please note the fan I used is a lot quieter with air noise but unless it is installed with rubber washers or ideally rubber 'stretchy bolts' it does buzz a bit. It will still be a lot quester but not as silent as you might want.
Adam
Old 09-11-2009, 4:40 PM   #4
11,342, Level: 25
Adam,
The fan is really noisy and I find myself turning the TV up to drown it out so anything quieter will be good. Just worries me about the warranty. I will have a look.
cheers
Graham
Old 09-11-2009, 6:07 PM   #5
3,533, Level: 13
Points: 3,533, Level: 13 Points: 3,533, Level: 13 Points: 3,533, Level: 13
Thanks: Gave 4, Got 12
I just installed the RS fan from the link above, straight forward install.
very very quiet now.
Old 09-11-2009, 10:50 PM   #6
AVF Hardware Reviewer
Russell.Williams's Avatar
34,278, Level: 45
Points: 34,278, Level: 45 Points: 34,278, Level: 45 Points: 34,278, Level: 45
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 745, Got 1,452
Likewise, mine is much quieter although a touch buzzy as I have yet to be bothered to find the requisite rubber washers.
Isn't there a good thread on this very subject already, or has the search button fallen off?
Russell
Old 10-11-2009, 8:27 AM   #7
Conspicuous Member
18,418, Level: 32
Points: 18,418, Level: 32 Points: 18,418, Level: 32 Points: 18,418, Level: 32
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 263, Got 636
Russell
What search button?
Old 10-11-2009, 9:24 AM   #8
11,342, Level: 25
What there is such a thing as a search button. God I didn't realise that. Thanks for pointing that out to me.
cheers
Graham
Old 10-11-2009, 9:27 AM   #9
Conspicuous Member
AngelEyes's Avatar
29,366, Level: 41
Activity: 22.3%
cheers
Graham
I also noticed you visited the thread in question when it was created and even left your thanks
Adam
Old 10-11-2009, 9:29 AM   #10
11,342, Level: 25
That was before I got the amp though so everything else was on the go.
Sometimes it is good to read and ask questions, saves things going wrong.
cheers
Graham
Old 10-11-2009, 6:52 PM   #11
Conspicuous Member
Moonfly's Avatar
24,796, Level: 38
Activity: 22.8%
I wander, how about fitting a variable resistor so you can simply turn the fan up and down at will?
Old 10-11-2009, 7:43 PM   #12
Conspicuous Member
18,418, Level: 32
Activity: 5.7%
This has been much discussed elsewhere.
The consensus is that DC motors don't like to start (reliably) on inadequate power.
The same goes for such ideas like doubling up 12V motors in series.
Find a low noise, 24V fan and be safe seems to be the best advice.
As does letting it blow forwards. Rather than sucking dirt into the case through every available orifice.
If one can find a suitable plug to fit the printed circuit board then the fan can be swapped without soldering or cutting the original fan wires. The original plug is a nested arrangement of two parts. I finally found one on a discarded computer fan on a car boot stall where the vendor had all sorts of computer "junk". You may have a similar outlet nearer home. I was told these plugs for computer fans were once common but now obsolete.
Old 10-11-2009, 9:20 PM   #13
stevefish69's Avatar
9,666, Level: 23
Points: 9,666, Level: 23 Points: 9,666, Level: 23 Points: 9,666, Level: 23
Thanks: Gave 866, Got 371
Does anyone have a pic of the plug in question. We use various plugs and connectors at work on our PCB's / fans and i may have some knocking about.
If one is not up to soldering / splice (you know who you are ) then a simple connector block or red devil (Butt splice) would do the trick if the old plug is removed with a short bit of wire.
Just make sure that you match the current rating of the fans. I swapped out a 24v fan on my Cinepro and nearly killed the amp. The original was rated at 0.04amps and the new one at 0.45amps. I only noticed when i fired it up and it started to smoke Just ensure you make a not of the power rating and not just the voltage
Old 10-11-2009, 10:28 PM   #14
Conspicuous Member
18,418, Level: 32
Activity: 5.7%
Plug
Original Behringer fan
stevefish69 (11-11-2009)
Old 11-11-2009, 7:59 AM   #15
Conspicuous Member
Moonfly's Avatar
24,796, Level: 38
Activity: 22.8%
Doubling up fans in line with each other never ever works anyway. Even in big industrial venting system you never arrange fans like that. Only one fans is doing anything, as the second fans has no load (due to the first fans doing all the work). Mechanically speaking, thats a bad idea, twin fans should always be arranged side by side which I doubt would be possible on the Behringer without some serious modding.
Old 13-11-2009, 12:30 AM   #16
Illustrious Member
namuk's Avatar
40,920, Level: 49
Points: 40,920, Level: 49 Points: 40,920, Level: 49 Points: 40,920, Level: 49
Activity: 59.5%
Activity: 59.5% Activity: 59.5% Activity: 59.5%
Thanks: Gave 1,068, Got 2,470
Use theses Instead of Washers , you will get a better Seal Ect.
Welcome to Vantec – Leading Brand of Storage, Thermal, and Mobile Accessories! - Product
i think this shop has a assured adviser on here not sure though .
Quiet PC UK - Quiet Computer Hardware for a Quiet PC
AngelEyes (13-11-2009), Moonfly (13-11-2009)
Old 13-11-2009, 10:58 AM   #17
Conspicuous Member
18,418, Level: 32
Activity: 5.7%
Don't forget the 24V.
Old 13-11-2009, 11:47 AM   #18
11,342, Level: 25
I thought that too.
Graham
