Ancient History... for anyone interested :)
Old 29-10-2009, 11:58 PM   #1
IronGiant's Avatar
25,200, Level: 38
Points: 25,200, Level: 38 Points: 25,200, Level: 38 Points: 25,200, Level: 38
Activity: 27.4%
Activity: 27.4% Activity: 27.4% Activity: 27.4%
Thanks: Gave 2,344, Got 4,993
RELinquished circa 2003
Built with this homemade jig instead of a £1500 jobby :
Looking through my old notes I apparently used a DIY 30mm nailgun to lightly pin the panels in place before finally locking the biscuit joints in place with a couple of screws. So I might have to change that post in another thread about DIY nail guns only being suitable for rabbit hutches
Please note the 4 screws on the front panel
Dave
AngelEyes (30-10-2009), Moonfly (30-10-2009), theritz (13-11-2009)
Old 30-10-2009, 2:04 PM   #2
Conspicuous Member
Moonfly's Avatar
24,796, Level: 38
Points: 24,796, Level: 38 Points: 24,796, Level: 38 Points: 24,796, Level: 38
Activity: 22.8%
Activity: 22.8% Activity: 22.8% Activity: 22.8%
Thanks: Gave 355, Got 1,104
Re: Ancient History... for anyone interested :)
Whatever happened to this then? Do you still have it, or any finished pics? This is doing my head in not being able to start mine yet. I did pick up my speaker binding posts from Maplin yesterday though, so I'm kinda doing bits here and there
Old 30-10-2009, 5:33 PM   #3
Conspicuous Member
18,418, Level: 32
Points: 18,418, Level: 32 Points: 18,418, Level: 32 Points: 18,418, Level: 32
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 263, Got 636
Dave
Do tell us more.
Do you have a bigger image of this jig of yours?
The amp looks decent with a nice big toroidal transformer.
Old 01-11-2009, 11:54 AM   #4
6,344, Level: 18
Points: 6,344, Level: 18 Points: 6,344, Level: 18 Points: 6,344, Level: 18
Thanks: Gave 6, Got 73
BSB12 and BSB100 or 200, so IIRC a similar to a REL Q100(e).
Old 01-11-2009, 6:45 PM   #5
IronGiant's Avatar
25,200, Level: 38
Activity: 27.4%
Spot on it's the BK 100 amp panel and it was a REL Q100e clone. A number of us who built one later upgraded the driver and I later moved it and the amp panel into my current sonotube that was built by Mat-Moo. The box was dressed in a speaker fabric cover with a slab of black granite on top.
The jig was designed to run a circular saw in to enable keeping a straight cut easily. Not sure if I can find a larger pic but I'll look.
Dave
Nimby (02-11-2009)
Old 01-11-2009, 9:13 PM   #6
AVF Hardware Reviewer
Russell.Williams's Avatar
34,278, Level: 45
Points: 34,278, Level: 45 Points: 34,278, Level: 45 Points: 34,278, Level: 45
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 745, Got 1,452
Your point?
I just feel safer having used 114 (in total on the whole box) and yes I did count them.
Russell
Old 02-11-2009, 8:52 AM   #7
Conspicuous Member
Moonfly's Avatar
24,796, Level: 38
Activity: 22.8%
Studies show that using 115 screws is significantly more effective as 114 doesnt reach the exact threshold of strength required for optimum fastening on a box of that size using 1" MDF. Sorry to tell you this, but your going to have to start again.
Old 02-11-2009, 11:48 AM   #8
IronGiant's Avatar
25,200, Level: 38
Activity: 27.4%
Originally Posted by Russell.Williams View Post
Your point?
Russell
I thought you might spot that comment I was illustrating a different construction technique Russell, using glue and biscuits with screws in a supportive role, But I certainly wasn't trying to imply it was any better than yours
Dave
Old 02-11-2009, 12:19 PM   #9
Conspicuous Member
18,418, Level: 32
Activity: 5.7%
Ideally we need a graph to show the tipping point where 114 screws is totally inadequate and 115 more than you will ever need.
Mmm. Biscuits! Chocolate digestives, anybody?
Old 02-11-2009, 12:20 PM   #10
6,344, Level: 18
Screws is always a debate with subwoofer building.
You certinaly can go too far with screws and weaken the wood connection though a reduction of surface area for the glue to use and a splitting of the wood in various places.
Also a badly driven in screw can pull the wood join apart and a correctly driven in screw can keep things tight.
Old 02-11-2009, 12:25 PM   #11
11,342, Level: 25
Points: 11,342, Level: 25 Points: 11,342, Level: 25 Points: 11,342, Level: 25
Thanks: Gave 24, Got 43
I disagree... Over 250 in mine and I have not split the wood once. All piloted and is solid as a rock. I made pilot holes in the wood I was screwing in to. No splits.
cheers
Graham
Old 02-11-2009, 12:30 PM   #12
Conspicuous Member
AngelEyes's Avatar
29,379, Level: 41
Points: 29,379, Level: 41 Points: 29,379, Level: 41 Points: 29,379, Level: 41
Activity: 23.6%
Activity: 23.6% Activity: 23.6% Activity: 23.6%
Thanks: Gave 324, Got 786
No screws
Old 02-11-2009, 12:36 PM   #13
11,342, Level: 25
Show off! Lets hope when you turn it up loud it doesn't collaspe.
cheers
Graham
Old 02-11-2009, 12:39 PM   #14
Conspicuous Member
AngelEyes's Avatar
29,379, Level: 41
Activity: 23.6%
No chance . Have fun filling and sanding those holes chaps
Adam
Old 02-11-2009, 12:51 PM   #15
11,342, Level: 25
Done it already, didn't take long at all. Found it some what relaxing.
cheers
Graham
Old 02-11-2009, 1:03 PM   #16
Conspicuous Member
Moonfly's Avatar
24,796, Level: 38
Activity: 22.8%
I'm sure there is a link somewhere showing this, and the exact torque setting required on each screw to hit this point exactly. Go to far and you shorten the lifespan of the cabinet material
