| Re: DIY M&K In Wall Sub - will it sound good?
You have brickwork interior walls and brick work exterior wall with an insulation filled gap in between. What type of insulation is it? That is, is it soft fiber insulation or stiff foam insulation?
If it is soft fiber insulation leave it there. If it is ridged foam insulation, that complicates things as the foam leaves no space for the required speaker volume.
Next, are there barriers in the walls? Boards, rafters, studs, etc? The cabinet volume is all the horizontal and vertical space available until you run into some type of barrier. In standard wood and plaster construction walls, that would be a space 17" wide, by 8' tall, by 3.5" deep or (17 x 96 x 3.5 = 5712 / 1728 = 3.31 cubic feet).
Next if the interior wall is brickwork, how do you plan to cut a hole to accommodate the speakers. Are you going to try to cut a precise round hole for the speaker? Or, are you going to cut out a large square section, mount the speaker to a board, then mount the board to the brick?
Then the next question is, do you really feel you can adequately secure the speaker or the speaker board to the brick?
And do you feel that cutting a large section of brick out of the wall is going to devalue your house?
Next question, is the interior brick exposed, or is it covered with some type of wall board?
Next, unlike brick houses in the USA where the brick is merely a facade, I assume the brick in your house is part of the structural integrity of the house. Are you undermining that structural integrity but cutting into the brick?
A lot of things to consider. Personally, with brick interior walls, either build a false wall or build stand alone cabinets.
The false wall doesn't even really have to be a full false wall. It could be more like wainscot. You could build a section out from the wall, say about 3 feet high and 12" to 16" deep. Sections of it could be enclosed for your subwoofers, and sections of it could be shelves for you equipments. The top area could be a slightly wider shelf to set the TV on, or just general odds and ends (books, etc...).
Just a few thoughts.
Steve/bluewizard
