Re: bluray films not many with dolby true hd.
PCM - Pulse Code Modulation - Encoding Analog Signal into Digital form using 8-bit samples (quantization). It's Uncompressed, closest to the studio master and occupies more space. In Blu-rays PCM tracks are encoded at either 16-bit (4.6 Mbps CBR) or at 24-bit (6.1 / 6.9 Mbps CBR). The optical / coaxial outputs are NOT capable of transmitting high bit rate audio (> 1.5 Mbps).
PCM in Blu-ray is being used as a stop gap measure as the grace period profile doesn't mandate advanced audio formats.
In another 1-2 years Studios may drop LPCM in favor of Lossless/Compressed audio formats that occupy optimal space and produce similar audio quality like that of PCM.
Btw PCM is not a new concept. It's been there since ages.
Blu-ray : 110 + 3 + 4 + (1 + 3 + 1) ; HD DVD : SAYONARA
