07-03-2008, 5:00 PM
#1 (permalink)
Thanks: Gave 14, Got 10
7.1 and 6.1 BD/HDDVD
well i have finaly got around to wiring up my back speakers
anyone know of any disks with 7.1 or 6.1 ?
07-03-2008, 5:13 PM
#2 (permalink)
Thanks: Gave 701, Got 823
Re: 7.1 and 6.1 BD/HDDVD
It depends on what audio decoding you are using, on what players. The vast majority are fixed to 5.1 even when they have 7.1 outputs.
Do everything with excess, even excess
07-03-2008, 6:00 PM
#3 (permalink)
Thanks: Gave 913, Got 4,977
Moved.
Pioneer KRP-600M, Onkyo 876, M&K LCR 750, M&K M4T, SVS SB12+, PS3, Oppo 983, S5000ES , XE1, Logitech 1000 remote, wildlife pond in back garden.
Be a man.........make a compost heap!
07-03-2008, 11:02 PM
#4 (permalink)
Thanks: Gave 63, Got 519
for bluray, good luck chuck,war,and 310 to yuma have 7.1 pcm audio, so you should get that no problem as long as your amp accepts 7.1 pcm which most should do, other discs such as rush hour 3 and shoot em up have dts ma 7.1 audio, however to get these you need a player that outputs the hd audio in bitstream format and an amp with onboard dtsma decoding.
The same applies with hddvd,you will need a player which bitsreams the hd audio and an amp with onboard decoding.
Samsung LE40R88BD ,Optoma hd70,Harmon Kardon AVR255,Mordaunt Short Avant 309i Subwoofer,Mordaunt Short Avant 906i Floorstanders, Mordaunt Short Avant 905i centre ,Mordaunt Short Avant 903i bipoles,Mordaunt Short 902i surround back ,Skyhd,PS3,XBOX360,HE-1,E-30,XBOX360,Samsung BDP1500
08-03-2008, 12:34 AM
#5 (permalink)
Thanks: Gave 18, Got 83
I must admit, when I installed my back surrounds I have noticed a marked improvement in the surround sound panning. As mentioned the above dedicated extra surround movies are great but also I get fantastic sound from 5.1PCM tracks aswell in PCM DD PLIIx.
PC| E8500@4.04GHz | COOLERMASTER 1KW | 4GB XMS3 DDR3 | HD2900XT 1GB | P5K3DELUXE | SPINPOINT 320GB | LIAN LI V2100B+2 |PC
AV| VSX LX-60 | 42PD7200 | DMREX77 | DMP BD-35 | BK XLS200df | MA BRONZE | M5DS | M3DSi |7.1 GEAR
