AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Movies, TV Programmes and Music > On Disc and Downloaded
LinkBack Thread Tools Display Modes
Old 03-03-2008, 2:30 PM   #1 (permalink)
Thanks: Gave 10, Got 5
Question Blu ray: How does scratches affect them........
.......compared to standard dvds?
I rent dvds from Lovefilm and some freeze due to scratches.
Will blu ray react the same way?
My system:
Pioneer PDP-436XDE; Onkyo TX-SR705E; Samsung BD-P1400 blu ray; Panasonic DMREZ27EB; Humax PVR-9200T; Velodyne CHT15; Speakers: Monitor Audio S6; MA SLCR; Rear speakers: MA SFX; Arcam 8R amp and 8P power amp; Arcam alpha 8 cd player (upgraded to CD82); Project Debut turntable
SOUNDSTYLE is offline
Old 03-03-2008, 3:18 PM   #2 (permalink)
ijd
Thanks: Gave 94, Got 146
Re: Blu ray: How does scratched affect them........
unfortunately as blue ray uses a much smaller footprint than conventional dvd this is going to be a major issue, it is also positioned much closer to the the disc
this.it would not of been as much of a problem on hd dvd,as the lens is position further away, but that is another story
please dont start your paragraph or sentence with BASICALLY
http://www.speedtest.net/result/177388255.png
ijd is offline
Old 03-03-2008, 3:51 PM   #3 (permalink)
Thanks: Gave 199, Got 44
Funny you should say that because I found the total opposite when I used to rent off Lovefilm. I rented 47 Blu- Rays and not one failed to play 100% and then hired 4 Hd-dvd's and only 1 of them played faultlessly, the other three were horrendous, and would either not play at all or just keep breaking up all the time.
philbam is offline
Old 03-03-2008, 3:56 PM   #4 (permalink)
Thanks: Gave 29, Got 247
Blu-Ray does seem to play easier then HD-DVD
But most of my problem disks were combos
pjclark1 is offline
Old 03-03-2008, 3:57 PM   #5 (permalink)
Ger
Ger's Avatar
Thanks: Gave 132, Got 65
This was a problem with the disks to start with (they were originally housed in a cartridge), but was solved (by Phillips, I think) with a very durable coating on the disk's surface.
<embed><object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/o5jEbZt6AIQ"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/o5jEbZt6AIQ" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object></embed>
EDIT: I can't get this youtube clip to embed. Can anyone do it for me?
Ger is offline
Old 03-03-2008, 4:07 PM   #6 (permalink)
vader100's Avatar
Thanks: Gave 103, Got 36
Yes. I read somewhere that the BD discs are coated in a more durable material than DVD but I can't for the life of me remember where.
You can't take the sky from me.
Sony KDL-S40A12U, PS3(UK), Panasonic DMR-EX77, Onkyo 606, Tannoy EFX 6.1 speakers
vader100 is offline
Old 03-03-2008, 4:13 PM   #7 (permalink)
Ger
Ger's Avatar
Found the following: http://www.durabis.com/en/con00100.htm
It was TDK who developed the new coating (called "durabis").
Ger is offline
ijd (04-03-2008)
Old 03-03-2008, 4:58 PM   #8 (permalink)
Pincho Paxton's Avatar
Thanks: Gave 30, Got 192
I can link to it...
http://www.youtube.com/swf/l.swf?vid...quWCYl0R47zZf7
The seating distance thing is quite annoying. Yeah it looks great from 20ft away.. so does my ex!!!. If you can ignore grain, then it's easy to ignore someone that is sending out a lot of noise that you don't like to hear. By the way, I'm being artistic. But maybe you just don't get it.
Pincho Paxton is online now
Old 03-03-2008, 6:04 PM   #9 (permalink)
Thanks: Gave 38, Got 17
I've noticed its easier to mark or scratch a Blu Ray disc than it is an HD DVD.
Not saying i've tried on purpose but i've had a few discs freeze in my PS3, when checking the surface it might just have a smear on it and usually from the disc mechanism as the PS3 drags the disc through the slot. a quick clean and its fine.
Never had any problems with HD DVD. and i thought one of the great things about Blu Ray was it was tougher.
Remember the same being said about DVD
Sharp LC37 XD1E/Onkyo TXSR705/Mordaunt Short Avant 900i 5.1 System/Xbox360 with HD DVD add on/60gig PS3/Samsung HD950
cascade is offline
Old 04-03-2008, 12:19 PM   #10 (permalink)
ijd
i remember when CDs came out and the guy in the shop demo-ing smeared jam on the printed surface announcing that they were indestructible, however when i asked if the disc played on both sides he went a bit, so i asked him to smear jam on the other side to which he refused as he did not want to get jam on his player needless to say his sales patter left him feeling as i walked out of the door
ijd is offline
Old 04-03-2008, 12:32 PM   #11 (permalink)
Thanks: Gave 12, Got 58
Hmmm, I own nearly 100 BD movies and not one of them has is scratched even slightly. The only discs that have any marks on them are the two DVDs from the US Blade Runner 5-disc DVD/BD set.
I order my movies online and on more than one occasion the discs have come loose in the post but none have ever arrived with so much as a scratch on them. Unlike DVDs!
/remembers the Halo 3 Collector's Edition fiasco
My sister even bought me Halloween on BD for Christmas but knowing how fussy I was about looking after my movie discs warned me that she thought the disc was loose before I opened my present on Christmas Day. I just laughed, shook the box to confirm it - she absolutely looked mortified - then opened it and showed her that the disc didn't have a scratch on it! If that had been a DVD it would have had scratches all over it.
Seems to me that while BDs are not entirely scratch-proof - I'm sure I could mark them if I tried - they're certainly more scratch-resistant than DVD or HD DVD. I couldn't be happier as I no longer have to worry about the discs coming loose in the post now for my movies or PS3 games!
Darren
Doctor Hades is offline
Old 04-03-2008, 6:13 PM   #12 (permalink)
Thanks: Gave 76, Got 11
hi
i rent of lovefilm and eastern promises on bluray i was unable to play it did not even load up on the ps3 tryed others and they work fine , i checked the back of the cd and it had scratches all the way around it , only small scratches , i just dont get why people who rent films dont take more care,if everyone looked after there rented films perhaps we would all never have problems
gunner84 is offline
affect, blu, ray, scratched
Refbacks are On
Thread Thread Starter Forum Replies Last Post
DLP TV Scratched Constantine769 Rear Projection Televisions 11 17-03-2008 6:14 PM
New tv scratched!!!! scottie-vrs LCD Televisions 6 12-12-2007 3:23 PM
Scratched allgoodh LCD Televisions 3 17-10-2007 4:48 PM
Scratched my LCD- Can anything be done? deltatri360 LCD Televisions 4 18-09-2006 11:13 AM
Scratched Lcd ajbeech LCD Televisions 0 19-03-2004 11:08 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
