Originally Posted by Tomdarkness Hey,
My parents live in a smallish (~20 apartments) block and currently only have a shared analogue aerial (They can't even get Channel 5!) and are being given the run around by the managment company as to gettting a digital aerial installed.
I was just wondering why it is so difficult to get the old single analogue aerial shared installation upgraded and why the managment company don't feel inclined to do it?
Does it require recabling of the whole block or something? (Not sure why it would though as it uses the same cable, right?)
Thanks, Tom |
Though aerials come in different "strengths", there is no such thing as an analogue or a digital aerial. Provided your parents live in a locality where the Freeview digital signal is received at all, then it would be unusual for a Freevew tuner to register zilch. Some channels might be missing, and those received might break up - but you would expect to see something.
It's not entirely clear from your post whether there is defective Freeview reception or no reception at all. If reception is defective, then yes it sounds as though the aerial needs upgrading - but the cabling to individual flats should not need any adjustment. I don't know why any management company should be reluctant to do this, unless as Mike7 suggests they're waiting for switch-over to see if the situation improves by itself. (Presumably, the costs of aerial upgrading would be recovered through the service charge.)
By the way, I take it you're sure that reception
is via a terrestrial aerial. There have been some posts by residents of flats, who think they're getting terrestrial TV, but it's turned out to be an old cable service they've been unaware of.
