Humax PVR No BBC?!
Old 04-11-2009, 5:14 PM   #1
3,167, Level: 13
Points: 3,167, Level: 13 Points: 3,167, Level: 13 Points: 3,167, Level: 13
Thanks: Gave 2, Got 0
Humax PVR No BBC?!
Retuned the parents PVR this eve of the switch over, 1 & 2 were gone so I retuned and they are still no where to be seen? any ideas?? The TV hooked upto the PVR can get BBC 1 & 2.
My Topfield is ok!
Old 04-11-2009, 7:34 PM   #2
4,353, Level: 15
Points: 4,353, Level: 15 Points: 4,353, Level: 15 Points: 4,353, Level: 15
Thanks: Gave 1, Got 4
Re: Humax PVR No BBC?!
My Topfield is ok!
Actually i do know and well chuffed i am to be a member of this forum because up until this morning i was clueless and just as stuck Right..... You need to delete all your radio and tv channels by going into the edit channel lists and selecting them all then pressing delete. Following this you need to go into the manual tune menu and search on the appropriate channel for the transmitter within your area, now i know the channel numbers for the winter hill region but you will need to go onto the digital uk website and use their postcode finder to find your transmitter and then the appropriate channel numbers.
When you do go into the manual tune option just remember to enable the search button at the bottom of the page (it will show disable at the moment). Then enter the channel number at the top and search away.
Paul C 2007 (04-11-2009)
Old 04-11-2009, 10:16 PM   #3
3,167, Level: 13
Just got in and read your post, a factory reset sorted it
Old 05-11-2009, 1:04 PM   #4
9,515, Level: 23
Points: 9,515, Level: 23 Points: 9,515, Level: 23 Points: 9,515, Level: 23
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 194, Got 668
had the same problem on a humax8000t pvr , channel rescan did not fix it but a factory default reset did
just had to setup no subtitles , cvbs and 16:9 again
Old 05-11-2009, 2:38 PM   #5
28,191, Level: 40
Points: 28,191, Level: 40 Points: 28,191, Level: 40 Points: 28,191, Level: 40
Activity: 89.2%
Activity: 89.2% Activity: 89.2% Activity: 89.2%
Thanks: Gave 39, Got 2,263
For reference Winter Hill now uses 56 62 63 66 67 and 68
