Originally Posted by Triassic I've relocated my aerial to the highest point of my roof so as to get a better line of sight to Winter Hill (36km away) but I still have poor picture quality, with pixilation and freezing of the image.
I've started trouble shooting the problem and need some advice - my aerial coax is routed close to the incoming overhead power supply. Will the power supply interfere with the signal and if so how much separation do I need? |
I could be worth using sat grade cable which has better screening but I very much doubt if that will make a lot of difference, your symptoms are usually as a result of not enough signal.
This may interest you
Satellite, Television, FM, DAB Aerial Cable, Plugs, Sockets, Connectors & Leads
If you put your postcode in here and post what aerial is recommended then may be able to help more.
UK digital TV reception predictor
Winter Hill needs C/D aerial or a log periodic wideband if you have enough signal and you may also need to fit a mast head amp. Log periodics have excellent interference rejection a flat gain curve but don't work very well in fringe areas due to lack of gain.
See here for best aerials for your transmitter
ATV`s Choice Of Aerials
