Originally Posted by TyD What is a pvr? I just want to replace the Video Recorder that doesn't accept digital signals.
Ty |
A pvr (personal video recorder) records the digital TV transmission direct to a hard disc drive. Most have two tuners and can record two different channels at the same time. Some (notably Topfield and Humax models) allow you to view a limited choice of 3rd channels. Newer ones support freeview+ which allows you to record every episode in a series by simply clicking on the programme in the electronic programme guide (EPG) and selecting the series option. You can also view an existing recording while recording two new programmes.
Because the original programme data is copied to hard disc there is no quality loss in the recording.
Because the channel data is buffered to a disc you can do clever things like pause live Tv and skip over adverts. Some allow the recorded programmes to be transferred to a computer and these can then be burnt to DVD
You can connect a freeview set top box to your existing recorder to record digital TV if you wish.
