freeview nightmare + grumpy daughter
Old 15-10-2009, 1:04 PM   #1
1,403, Level: 8
Points: 1,403, Level: 8 Points: 1,403, Level: 8 Points: 1,403, Level: 8
any help would be greatly appriciated my daughter has a viewpia 19" freeview lcd tv with built in dvd player its just over a year old and after the change it will find up to 75 channels but cannot display them it just comes up with no signal on the screen. i can tune in bbc itv channel 4 and 5 on normal tv but nothing on the freeview channels. i have tried it on 4 different ariels at different houses but to no avail. thoughtfully my daughter has thrown the instruction manual away and i have had no response from the manfacturer there is no factory reset or anything else that could help. am i just being stupid and overlooked somthing simple or am i forking out for another new tv. any help would be greatly recievied
Old 15-10-2009, 2:02 PM   #2
28,191, Level: 40
Points: 28,191, Level: 40 Points: 28,191, Level: 40 Points: 28,191, Level: 40
Activity: 89.2%
Activity: 89.2% Activity: 89.2% Activity: 89.2%
Thanks: Gave 39, Got 2,263
Re: freeview nightmare + grumpy daughter
Can you manually delete all the existing channels before retuning ?
Old 15-10-2009, 2:13 PM   #3
1,403, Level: 8
there are no channels stored . it finds about 75 channels and some radio stations then says please wait then the screen goes blank and a screen saver type message comes up no signal.
Old 15-10-2009, 3:14 PM   #4
28,191, Level: 40
Activity: 89.2%
Is there a manual tune option for the digital tuner ?
Old 15-10-2009, 4:05 PM   #5
1,403, Level: 8
it has a manual tune but that doesnt tune anything either unless im doing it wrong
it just says please wait then nothing
Old 17-10-2009, 6:28 PM   #6
2,963, Level: 12
Points: 2,963, Level: 12 Points: 2,963, Level: 12 Points: 2,963, Level: 12
Thanks: Gave 96, Got 110
from another website:
click menu, on station prog go to EDIT. Press blue button twice, then go to rescan prog. (it seems to clear all previous scanned programs and starts again.
good luck
Old 19-10-2009, 11:49 AM   #7
1,403, Level: 8
thank you thank you thank you
for eveyone who took the time to help me with my problem
it all works perfectly after following jimiaces advice
thank you again one happy daughter
thanks
