DAB - Will signal get better after switch off?
Old 10-10-2009, 10:32 AM   #1
5,470, Level: 17
Points: 5,470, Level: 17 Points: 5,470, Level: 17 Points: 5,470, Level: 17
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 137, Got 137
In Manchester the digital switch off happens in November / December. Currently the DAB digital radio signal is pretty poor in our house unless the radio is near a window on the side of the house facing Winter Hill. Will the DAB signal get better after switch off?
Old 10-10-2009, 10:50 AM   #2
28,196, Level: 40
Points: 28,196, Level: 40 Points: 28,196, Level: 40 Points: 28,196, Level: 40
Activity: 88.5%
Activity: 88.5% Activity: 88.5% Activity: 88.5%
Thanks: Gave 39, Got 2,263
Re: DAB - Will signal get better after switch off?
I doubt it DAB uses band II VHF, formerly used by 405 line TV. The only reason DTT uses low power is to avoid co-channel interference with existing analogue transmitters sharing the same uhf channels. There is no reason that DAB transmissions are not at the their final power outputs as dso does not affect the VHF band at all. A band 2 loft aerial should give you a decent signal.
Old 10-10-2009, 11:18 AM   #3
12,569, Level: 26
Points: 12,569, Level: 26 Points: 12,569, Level: 26 Points: 12,569, Level: 26
Activity: 36.8%
Activity: 36.8% Activity: 36.8% Activity: 36.8%
Thanks: Gave 218, Got 320
With respect, I think you mean Band III
Old 10-10-2009, 12:14 PM   #4
5,470, Level: 17
Activity: 5.7%
But a large fixed aerial isn't the best option for a small portable radio Seems crazy that old school MW Radio Five Live is much more reliable than DAB Five Live...
Old 10-10-2009, 12:54 PM   #5
28,196, Level: 40
Activity: 88.5%
Quite right, apols for the error. Same comments apply though
To the OP possible alternatives, Freeview radio, Satellite based digital radio and internet radio which for most channels have a better bitrate than DAB anyway, not mention good old Analogue FM.
http://www.digitalradiotech.co.uk/
Old 25-10-2009, 2:55 AM   #6
1,504, Level: 8
Points: 1,504, Level: 8 Points: 1,504, Level: 8 Points: 1,504, Level: 8
Thanks: Gave 2, Got 0
I have learnt that DAB's reception is poorer than analogue FM. Is the signal strength of DAB poorer than analogue FM? If so, it will make the audiance totally disappointed as they paid much higher price for poor quality of radio. How can it take over the analogue FM going forward? Totally opposite to digital TV!!
Old 25-10-2009, 7:21 AM   #7
Chris Muriel's Avatar
15,704, Level: 30
Points: 15,704, Level: 30 Points: 15,704, Level: 30 Points: 15,704, Level: 30
Activity: 10.8%
Activity: 10.8% Activity: 10.8% Activity: 10.8%
Thanks: Gave 510, Got 629
Whether or not the DAB signal strength is lower depends entirely on a user's location. For some folks DAB will be stronger, for others FM will win - remember that the VHF/FM service is mature system whilst DAB is relatively new.
Old 25-10-2009, 9:17 AM   #8
1,504, Level: 8
This is not an excuse for poor DAB signal. Although it is relatively new, it transmits a couple of years already. The radio has been evolving from AM radio, FM radio, RDS and now DAB. The broadcasters have rich experience and the analogue radios are going to switch off. Otherwise, we should not talk about switching off analogue radios and resolve the poor reception with expensive receivers.
