retune sony HXD870 freeview
Old 29-09-2009, 1:12 PM   #1
1,044, Level: 7
Points: 1,044, Level: 7 Points: 1,044, Level: 7 Points: 1,044, Level: 7
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 9, Got 0
Hello All
This is my first post Help can anyone tell me how to tune my HDX870 sony for this freeview change please i have the manual but not the knowhow thanks in advance
Regards Gunner
Old 29-09-2009, 1:50 PM   #2
12,173, Level: 26
Points: 12,173, Level: 26 Points: 12,173, Level: 26 Points: 12,173, Level: 26
Thanks: Gave 0, Got 123
Re: retune sony HXD870 freeview
http://www.tvretune.co.uk/uploads/pd...895_retune.pdf
Would seem a fair starting point.
Old 29-09-2009, 2:44 PM   #3
1,973, Level: 10
Points: 1,973, Level: 10 Points: 1,973, Level: 10 Points: 1,973, Level: 10
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 7, Got 37
Hi. Its set out in the Manual page 131. Use the 'Replace Channels'. Should be straight forward but come back here if you have real problems.
Old 29-09-2009, 6:14 PM   #4
1,044, Level: 7
Activity: 0.8%
Smile Re: retune sony HXD870 freeview
Thanks Ray and Gaspode, thats taken a load off my mind now, this certainly seems a great site for us non techs
Thanks again Regards gunner
Old 30-09-2009, 3:10 PM   #5
28,196, Level: 40
Points: 28,196, Level: 40 Points: 28,196, Level: 40 Points: 28,196, Level: 40
Activity: 88.5%
Activity: 88.5% Activity: 88.5% Activity: 88.5%
Thanks: Gave 39, Got 2,263
There's a national problem with lcn 33, it's labelled ITV and has ITV2 + 1 contents in the epg
Old 30-09-2009, 5:57 PM   #6
9,515, Level: 23
Points: 9,515, Level: 23 Points: 9,515, Level: 23 Points: 9,515, Level: 23
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 194, Got 668
just bear in mind it will wipe any timers you have stored , so make a note of any timer settings , and add them back in after the replace channels is complete
it will also take a few hours to repopulate your epg so you will see a lot of blanks on ch5 and other affected channels
Old 30-09-2009, 6:43 PM   #7
Spamlet's Avatar
2,986, Level: 12
Points: 2,986, Level: 12 Points: 2,986, Level: 12 Points: 2,986, Level: 12
Thanks: Gave 1, Got 0
Can you tell me more on this Graham, I've just asked about it in the freeview updating thread.
It is not just ITV2+1.
Position13 is Channel 4 + 1, and Position 35 is now Virgin 1 +1 (That's if we are both talking about Guide Plus), but neither of these channels appears in the Guide Plus channels grid.
I get around this by setting a couple of the shopping channels that I normally have turned off, to 13, and 35, but it would be much easier to remember if the names on the grid could be edited.
Cheers,
S
Old 30-09-2009, 8:54 PM   #8
8,594, Level: 22
Points: 8,594, Level: 22 Points: 8,594, Level: 22 Points: 8,594, Level: 22
Thanks: Gave 286, Got 552
Being an optimist, I am confident that any of the above problems will rectify themselves automatically during the daily updates over the next couple of days.
Mine switches itself on at 10.00am every day for this, Fingers crossed.
