Sky digibox for freeview
Old 08-08-2009, 6:58 AM   #1
1,545, Level: 8
Points: 1,545, Level: 8 Points: 1,545, Level: 8 Points: 1,545, Level: 8
Hi, I have Sky+ in the living room with a digital/HD tv and a magic eye connection to a non digital tv in the bedroom. I still have the old Sky (Pace) digibox - can I use this in the bedroom to convert the tv to receive Freewiew channels and if so how?
Rob
Old 08-08-2009, 8:27 AM   #2
11,437, Level: 25
Points: 11,437, Level: 25 Points: 11,437, Level: 25 Points: 11,437, Level: 25
Activity: 12.5%
Activity: 12.5% Activity: 12.5% Activity: 12.5%
Thanks: Gave 257, Got 219
Re: Sky digibox for freeview
You cannot use a satellite box of any kind to watch Freeview. Freeview is a terrestial service delivered through a conventional aerial.
Old 08-08-2009, 11:16 AM   #3
4,270, Level: 15
Points: 4,270, Level: 15 Points: 4,270, Level: 15 Points: 4,270, Level: 15
Thanks: Gave 39, Got 101
But you can still use the Sky box to receive the FTA channels which are broadcast over satellite without a viewing card though no? So whilst not technically ' freeview' still receive most the channels..
Old 08-08-2009, 3:50 PM   #4
1,545, Level: 8
Thanks, The FTA channels look OK - would appreciate some advice as to how I should connect the digibox and tune it. I have the Sky remote controls that used to be with it. Magic eye and second (non digital) TV are now controlled by a Sky+ remote.
Rob
Old 08-08-2009, 5:07 PM   #5
4,444, Level: 15
Points: 4,444, Level: 15 Points: 4,444, Level: 15 Points: 4,444, Level: 15
Thanks: Gave 1, Got 71
Indeed, but the OP was going to connect an aerial (via the Sky+ box) to it, which won't work.
Since you have Sky+, you will have a quad LNB on the dish (i.e., 4 outputs -- two currently being used for Sky+), you can therefore run a new cable from the dish to your second TV location and Pace digibox to get the FTA channels.
Alternatively, if you have a rooftop aerial connected to the Sky+ box, you could buy a cheap Freeview digibox to use with your second TV.
