Originally Posted by grahamlthompson There's some confusion here 1080i 50 (the 50 refers to fields 1/50 sec each, and 2 are required for a full frame) and 1080p 25 (transmits 25 fields/sec with each field containg the full frame data) use effectively the same bandwith as both transmit 25 full frames/sec. 1080p 50 doubles the frame rate and is way beyond the bandwith available even using DVB-T2 and mpeg4 compression. Without massive improvement in encoders and compression techniques which would need all new equipment and is years away, transmitted 1080p 50 is a pipe dream. Even blurays which have a massive bandwidth capability only use 1080p 24 a direct 1920 X 1080 progressive scan of each frame of a 24fps movie negative. |
They don't use the same bandwidth because they're compressed. Only if they were uncompressed would they use the same bandwidth. Progressive video is easier to compress than interlaced video. So 1080p50 would not be way beyond the available bandwidth. It could be compressed using current bitrates. How good it would look would depend on the content, but for news or talk shows etc. it should be easy to compress even at lower bitrates (since the backgrounds of shots won't be changing very much) and would give better picture quality than the other formats. Since we have progressive displays it is a better format than 1080i25.
In any case to implement this would mean that every TV would have to be 1080p 50 capable. What about the millions of displays that are HD ready (including some early 1920 x 1080 displays).
No that's not the case. Blu-ray discs are usually encoded at 1920x1080p23.976, but you can still watch them on a 720p TV or one only capable of 1080/50i or 1080/60i. The Freeview HD decoders could/should be made to output at all current TV resolutions, including 720p, 1080i, 1080p etc.
Any increase in bandwidth capability would be much better used to increase bit rates to give as near as possible as a bluray 1080p24 picture which is currently the highest quality picture commercially available.
1080p24 is not good for sports, live TV, or for reproducing motion without judder or strobing. There's a reason there are never any live sports shot at anything under 50 frames/fields per sec - because anything less causes too much strobing/judder and won't capture with enough motion resolution. In fact the BBC say even higher frame rates should really be used since we have increased the spatial resolution of TV but not the dynamic (motion) res.
http://downloads.bbc.co.uk/rd/pubs/w...les/WHP169.pdf. So all we have done is made more pixels blur on movement and/or make the picture strobe more.
In fact on Blu-ray, 1080i30 (1080/60i) gives a technically better picture on Blu-ray (it's more pixels per second and gives 30 full frames per second) - though it does need de-interlacing. Other European stations have chosen 1080p50 and studios in the USA have chosen 1080p60. 1080p50/60 equipment (cameras, mixers etc.) are already available, and
1080p50 is recommended by the project manager of the EBU.
