| eddiewood | 21-02-2012 2:55 PM | Quote:
Originally Posted by godsakes
(Post 16453568)
if that were the case for NEX and presumably it not a problem for the likes of samsung NX and m34 etc then all that's stopping sony is adding a few mm to their lenses (like you would with a lens adapter).
Not sure but I suspect the problem is sony being morons rather than actual technical limitations | That'll be the problem, they'll not be able to make a 30mm (or whatever) pancake without making it too long/large. It isn't then a compact pancake and rather defeats the whole point of it. :grin:
So NEX offers the advantage of putting practically any lens on the front, but not if you want compactness. Maybe this compact will be Sony's answer to that problem? |
