Sony DSLR-A350.... £420 budget....
Old 10-04-2009, 7:06 PM   #1
7,331, Level: 20
Points: 7,331, Level: 20 Points: 7,331, Level: 20 Points: 7,331, Level: 20
Hi all,
after some help if you would.....
This will be my first DSLR....i have a budget of about £420....
i am looking at Sony DSLR-A350 Digital SLR Camera with 18-70mm Lens.
Any advice ???
Any others you think are better for the money ??
Thanks,
Andy.
Old 10-04-2009, 7:19 PM   #2
4,331, Level: 15
Points: 4,331, Level: 15 Points: 4,331, Level: 15 Points: 4,331, Level: 15
Thanks: Gave 43, Got 82
Re: Sony DSLR-A350.... £420 budget....
10 out of 10 for the A350 from me
Go for it ........
Old 10-04-2009, 7:34 PM   #3
8,847, Level: 22
Points: 8,847, Level: 22 Points: 8,847, Level: 22 Points: 8,847, Level: 22
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 251, Got 370
The A350 is a good cam but you do sacrifice some image quality for the tech. The range of Sony lenses is also getter better by the month. I would be inclined to go body only and buy a better after market lens. The 18-70 kit lens is not particularly good and you will only upgrade it anyway.
Old 10-04-2009, 8:25 PM   #4
paulyoung666's Avatar
5,692, Level: 17
Points: 5,692, Level: 17 Points: 5,692, Level: 17 Points: 5,692, Level: 17
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 266, Got 381
Originally Posted by I want a plasma View Post
Hi all,
Any advice ???
Thanks,
Andy.
if you aint handled one yet then i would go and handle the canon / nikon / pentax equivalents , i found the sony to be uncomfortable in my hands and settled on the canon 1000d , a camera is an extension of you , if it does not feel comfortable then you may find it annoying you to the point of uselessness
