Tripod to fit Lowepro 200
Old 29-03-2009, 7:57 PM   #1
468, Level: 4
Points: 468, Level: 4 Points: 468, Level: 4 Points: 468, Level: 4
Thanks: Gave 21, Got 2
Hi all, need a quick bit of help if you don't mind.
I'm after a sturdy tripod to fit into a Lowepro 200. Looking to spend anywhere around £100-150 but it must be sturdy and extend to a decent height (I'm 5'11 and would ideally like to take shots without too much stooping). Minimum height isn't really an issue.
I've had a look at both Manfrotto (283?) and Giotto's and just wondered what user's opinions were on here. Also, would these fit into the Lowepro?
Dave
Old 29-03-2009, 9:40 PM   #2
Dave's Avatar
27,064, Level: 40
Points: 27,064, Level: 40 Points: 27,064, Level: 40 Points: 27,064, Level: 40
Activity: 8.3%
Activity: 8.3% Activity: 8.3% Activity: 8.3%
Thanks: Gave 1,682, Got 2,205
Re: Tripod to fit Lowepro 200
I don't think such a tripod exists.
I've got a manfrotto modo 785SHB and that won't fit in my lowepro 200. I can stick it through a loop on the side for walks but it's not that sturdy and doesn't go that tall.
Chumpalot (29-03-2009)
Old 29-03-2009, 10:27 PM   #3
468, Level: 4
Thanks for that. I think I will need to rethink my bag choice in that case.
Old 29-03-2009, 10:29 PM   #4
Dave's Avatar
27,064, Level: 40
Activity: 8.3%
Has the tripod got to fit in to the bag?
If it hasn't then don't discount the lowepro because it's a fantastic bag. even if you got a bigger bag you'd still really struggle to fit a tripod inside it.
A lot of the larger bags do come with tripod carrying attachment straps though.
Old 30-03-2009, 4:15 PM   #5
468, Level: 4
It doesn't have to, no. If it strapped onto the sides I'd be perfectly happy with that.
I'm going to do a bit more research tonight I think.
