| Re: DSLR with a built-in stabilizer
IS really only comes into it's own at LOWER shutter speeds (say 1/80 and under). Whilst I'm probably right in thinking that lens stabilsed lenses are powered by the camera's battery, they'll likely to be 'always on' system (unless they have an OFF button). I've never used them, so don't know.
A basic 'rule of thumb' is to multiply the focal length by the camera crop factor (Sony is 1.5x), so for example, if shooting with a 300mm lens at 300mm x 1.5 = 1/450 sec shutter speed for regular unstabilised lens/bodies. And at that speed, you really don't need IS, so I usually switch it off. I find it a very nice feature not having to think to much when left on or worrying about if the shutter speed is to slow or if there's enough light in relation to aperture selected. Personally, it works for me (but then I'm a cheapskate).
Rules might alter for stabilised lenses, but for the in-body system, you can leave the system on, but be sure to turn it OFF if using a tripod or if on a stable platform (a wall for example) as you'll screw-up the internal IS system.
Not much (if anything) to choose between either variants other than the cost of glass. It's much the the same, but different!
