Wide angle lens for Canon EOS model.
Old 10-02-2009, 8:10 AM   #1
videonasty's Avatar
5,202, Level: 17
Points: 5,202, Level: 17 Points: 5,202, Level: 17 Points: 5,202, Level: 17
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 135, Got 35
I've been searching for a while now to try & find a good Wide Angle lens for my Canon 1000D DSLR. I've got a budget of £250-£300, but £300 is the utmost max, so more £250.
I've been looking at a few Tamron lens, but the Sigma lens also come with a good rep.
Could I have a few recommendations from people who use/have any wide angle lenses?
Old 10-02-2009, 9:15 AM   #2
7,818, Level: 21
Points: 7,818, Level: 21 Points: 7,818, Level: 21 Points: 7,818, Level: 21
Activity: 4.8%
Activity: 4.8% Activity: 4.8% Activity: 4.8%
Thanks: Gave 425, Got 577
Re: Wide angle lens for Canon EOS model.
How wide is wide?
The kit lens is 18-55mm (if you have it?) so if that isn't wide enough for you then you probably need to look at an ultra wide angle like the Sigma 10-20. Otherwise, the standard wide zoom that gets recomended a lot around here is the Tamron 17-50mm f/2.8.
Old 10-02-2009, 9:27 AM   #3
videonasty's Avatar
5,202, Level: 17
Activity: 1.0%
Originally Posted by T0MAT01 View Post
How wide is wide?
I sold the kit lens to buy the 55-250 IS lens. The 17-50 does look like a good lens. Thanks for your opinion.
