Originally Posted by sim667 Are they paying u any extra for it?
If not, just give em bog basic stuff.... |
That way you won't get asked again, you'll feel very unhappy and also, with an audience of 650 seeing your shots, there is a chance that it will lead to further things that might pay rather well
If you decide on the head and shoulders route have their shoulders at a slight angle to the camera and then get the subjects to turn their head towards you. This can give a more "natural" appearance; less of a passport look.
Had a look at some of the links earlier in this thread and found the lighting very flat in some of them. If you don't have much in the way of lighting equipment try using the light from a large north facing window. Turn the subject until the modelling is nice and use a large sheet of white card to fill in as necessary. You may need to warm up the results in post processing. The repeatability of flash light on stands is the way to go
if you can get the look you want.
It is best to use a tripod and have the subjects seated. Mark the position of the chair on the floor with some masking tape. Some people always move the chair as they sit down, some by accident, others in an attempt to take control of the situation
Once you're set up and shot a few off, try raising your head above the camera and smile at them. People react much more naturally to a persons face than someone hiding behind a camera. This is the main benefit of using a tripod. If you adopt this tactic check the focus after to make sure they haven't moved and avoid using too wide an aperture, you need a bit of depth of field to play with. Your priority is to get a good in focus picture not some arty 2mm of depth of field picture, most of which end up focussed in the wrong place. Its also best to review all your shots before you pack up using zoom mode in the camera to check focus, or better still a PC or laptop if handy.
The balance of aperture, shutter speed and ISO setting will depend on how large the final prints will be and at what distance they will be moved. Unless you do this sort of thing regularly it is very advisable to take some test shots and print up to finished size.
Look forward to hearing how you get on.
Cheers, Malcolm
