SanDisk RescuePRO
Old 17-01-2009, 4:11 PM   #1
4,426, Level: 15
Points: 4,426, Level: 15 Points: 4,426, Level: 15 Points: 4,426, Level: 15
Thanks: Gave 43, Got 10
SanDisk RescuePRO
I wasn't sure whether to piggyback on another thread or not but here goes...
I've bought a SanDisk Extreme III SDHC card from Amazon and their description says that it includes Rescue Pro software. Trouble is that there is no CD in the package. Searching AVF it seems that most buyers of SanDisk cards have had a CD in the Memory Card package. However I've read elsewhere that the software is on the Memory Card.
Can anyone confirm this? If not it's going back unless they want to send me the CD.
I've tried the SanDisk website and that seems to indicate that it comes on a CD.
Old 17-01-2009, 4:16 PM   #2
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Re: SanDisk RescuePRO
It comes on a CD ,, a small one in its paper package with own Serial No
This refers to the CF cards AFAIk. I have 3..
Old 17-01-2009, 5:50 PM   #3
3,903, Level: 14
Points: 3,903, Level: 14 Points: 3,903, Level: 14 Points: 3,903, Level: 14
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 2, Got 6
No CD in my box, or paper work, just checked
Old 17-01-2009, 5:57 PM   #4
4,426, Level: 15
Thanks - was yours a CF card or summat else?
Old 17-01-2009, 6:02 PM   #5
jomike's Avatar
9,090, Level: 22
Points: 9,090, Level: 22 Points: 9,090, Level: 22 Points: 9,090, Level: 22
Thanks: Gave 461, Got 377
If this is the 4GB £12.49 one, I did not get any software with mine either. At the price, and considering mine is the 30MB/s version, not the 20MB/s version as shown on Amazon, I was not too bothered.
wannaplasma (18-01-2009)
Old 17-01-2009, 6:48 PM   #6
JagoPlasma's Avatar
12,656, Level: 27
Points: 12,656, Level: 27 Points: 12,656, Level: 27 Points: 12,656, Level: 27
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 847, Got 387
yup i ordered 8gb extreme 20mb/s and got the 30mb/s with no cd. not fussed too much about cd as id use pc inspector anyway.
Old 17-01-2009, 7:40 PM   #7
47,154, Level: 53
Activity: 2.7%
Well if you do find you want it PM me..
Nothing wrong with PC inspector but having one or 2 of such programs to hand never hurts..
Old 17-01-2009, 7:49 PM   #8
Thanks: Gave 78, Got 67
Bought my sanDisk extreme III off Play.com for £10 got the software on a disk.
Old 18-01-2009, 10:04 AM   #9
D-an-W's Avatar
5,771, Level: 18
Points: 5,771, Level: 18 Points: 5,771, Level: 18 Points: 5,771, Level: 18
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 199, Got 126
Mine came with a 8cm CD with it on and a little Sandisk branded pouch thingy to store two Compact Flash cards in (16GB Extreme III from play.com).
Old 18-01-2009, 12:29 PM   #10
3,903, Level: 14
Activity: 0.7%
Sorry bad typing on my part, was the same as the OPs but when i said no paperwork i meant the cd wasnt inside the paper work
Kimbie
Old 18-01-2009, 6:45 PM   #11
4,426, Level: 15
Thanks. I didn't realise that there were other options and it seems that several people have amassed a pile of these and are willing to give them away so I'll cry for help if the occasion arises.
Thanks also to everyone else for chipping in
